Tires tires
   / tires #1
mit
any ever changed a tractor tire? i want to paint my rims with spray paint but i do not want to get paint on the tires.the rims has some rust and scrapes.would like to make it look good. how difficult to remove tires?
   / tires #2
If you haven't done it before and really, really want to paint the rims I suggest getting some jack stands and take all 4 tires to a tire shop. It's a tough job unless you have a bead breaker and some tire spoons, air compressor, experience, etc.
   / tires #3
I painted my 4 wheels for my trailer last weekend and I removed the wheels from the trailer and used 2 inch masking tape and trimmed the wheel edge with a razor knife and put another row around the edge of that and I had some minor over spray on tires that I washed off very easy.
I used a regular spray gun with very low pressure and I had real good control of paint
It was time consuming but the results are nice, I'll take some pictures this weekend and post them in my gallery here
Jim
   / tires #4
Jim
Same thing here. Masked the tires off and any overspray is easily removed with a little water and scotch brite pad or steel wool. Much easier than removing the tires.
   / tires #5
Duh, I did it the hard way ? I used Rust-O-leum paint and I used car gas and my tires look real purty now, real easy to do with the right stuff
LOL
Jim
   / tires #6
I'd just mask off the tires and paint them. Taking them off seems like too much work :cool:
   / tires #7
Well, I take the middle road. Use a tire spoon and hammer to move the bead down about 1/4 inch. Then cut cardboard to slide between the tire and rim, paint rim, remove cardboard, air tire.
done
   / tires
the masking idea sounds good enough for me.will give it as go .
2013 Ram 1500 Pickup Truck (A51692)
2013 Ram 1500...
2004 Kia Optima Sedan (A51694)
2004 Kia Optima...
2025 Swict 78in Bucket Skid Steer Attachment (A51691)
2025 Swict 78in...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53473)
2024 BCL...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
