Tires; tiny tires vs nails and debris
   / Tires; tiny tires vs nails and debris #1
megotatractor
Veteran Member
New Richland, Minnesota
JD 2210
considering sub compact unit, worried about the tires getting punctured when I start cleaning up two debris piles left over from an old farm. No I can't afford a dozer. /forums/images/graemlins/confused.gif
   / Tires; tiny tires vs nails and debris #2
Use Slime ahead of time /forums/images/graemlins/grin.gif
   / Tires; tiny tires vs nails and debris #3
<font color="red"> </font> Yes slime works great. Great product
   / Tires; tiny tires vs nails and debris #4
Gemplers has a "slime" type product available in 1 and 5 gallon sizes--I've got it in my tires, along with several screws and nails--works great.
   / Tires; tiny tires vs nails and debris #5
</font><font color="blue" class="small">( considering sub compact unit, worried about the tires getting punctured when I start cleaning up two debris piles left over from an old farm. No I can't afford a dozer. /forums/images/graemlins/confused.gif )</font>
If this is bigger piles with lots of debris?? It may be pretty big for that sub-compact? Not sure how big of piles but maybe for the larger projects maybe renting a dozer would be good. Not buying one but renting. Just a thought. Once you have the big mess cleaned up then take your new little sub-compact to finish up and keep you new sub-compact New.
murph
   / Tires; tiny tires vs nails and debris #6
After my first flat due to glass I had the front tires on my B2910 Kubota foam filled...no more problems...
I did not foam fill the rears. I decided to wait and see if I would get a puncture or not. The rears are only 4 ply R4s, but they did not puncture, so I liquid filled them.
The fronts on mine punctured so easily I decided I wanted a sure fix. It cost me something like $140 including the sales tax to have them filled. I am glad I did.
   / Tires; tiny tires vs nails and debris #7
My last tractors tires had slime in the tires and I never got another flat after I added it. Before that it was one thorn after another. Hard to believe those things are tough enough to penetrate a tire.
Anyway on my TC-40D I now use Multi Seal in all the tires. Check out a picture of the tire at their web site with all the screwdrivers sticking in the tire. It's a pretty good indication of how this sealant actually works. click here
   / Tires; tiny tires vs nails and debris #8
Does Slime work in tubed tires?
Ralph
   / Tires; tiny tires vs nails and debris #9
PineRidge,
Interesting stuff. I see they even make a product that will work with liquid filled tires, calcium cloride or other antifreeze included, and not just water. /forums/images/graemlins/cool.gif
   / Tires; tiny tires vs nails and debris #10
Pineridge,
About how much is it to do a tractor tire?
Land Honor Skid Steer Double Discharge Concrete Mixer (A50515)
Land Honor Skid...
City of Lakeland (A51691)
City of Lakeland...
2018 JLG 10054 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2018 JLG 10054...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
Farm Hand Silage Wagon (A50515)
Farm Hand Silage...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
