Tires Tires for B2150
/ Tires for B2150 #1
Milist
Mass./N,H.
B2150
I have a 1/4" hole in my rear turf tire for my B2150 4WD(calcium filled). I asked the repair facility to patch and tube. I was told that the inside of the tire has a 4" slice through the cords and that the patch/tube won't hold. Does this sound correct and if so what is the best price I can expect to pay for a replacement? or should it be a pair?
Also if I change to R4's, do I need new rims and would my front tires have to be changed as well?
/ Tires for B2150 #2
The B-2150 I used to have had Bridgestone turfs on it.
I think somewhere I still have an owners maual for a B2150.I will take a look and see what it designates.I am sure they all use different rims.at least they do on a BX2200.
/ Tires for B2150 #3
see if this works for You .It has the tire sizes that were available for the B2150 .
This is ultimately a .psf file once You Unzip it.only way I had to reduce it to a small enough file
/ Tires for B2150 #5
Milist,
If the tires have 800 hours on them I would replace at least both rears. Unless the machine has had little use in 4wd its probably a good time to replace the fronts as well. I checked my 2150 manuals and there is no mention of r4 sizes but I would guess that you would need 4 new rims. one of the newer b series tractors may use the same tire set as the 2150. if so that would give you the sizing info you'll need. Personally I would just put new turfs on. Unless you are spending most of your time on a paved surface the r4s won't do much for you.
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
POWELL (4) ROW FERTIZER DISTRIBUTOR (A64280)
POWELL (4) ROW...
2017 Dodge Journey SUV (A61574)
2017 Dodge Journey...
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
