I've posted this over-pressure info in another thread, but came across this tonight - it lists Goodyear's bulletin #:
I won't tow with ST tires much faster than 65 mph, and if I lived in the SouthWest, maybe not even that high...
Another important distinction between LT and ST tires is their speed ratings something a lot of RVers tend to overlook. Goodyear, maker of Marathon trailer tires, states in its bulletin PSB 2011-13: Industry standards dictate that tires with the ST designation are speed rated at 65 mph under normal inflation and load conditions. Based on these industry standards, if tires with the ST designation are used at speeds between 66 and 75 mph, it is necessary to increase the cold-inflation pressure by 10 psi above the recommended pressure for the rated maximum load. Increasing the inflation pressure by 10 psi does not provide any additional load-carrying capacity.
"Do not exceed the maximum pressure for the wheel. If the maximum pressure for the wheel prohibits the increase of air pressure, then the maximum speed must be restricted to 65 mph. The cold-inflation pressure must not exceed 10 psi beyond the inflation specified for the maximum load of the tire."
RV Tires 1�1
Rgds, D.
