Tires do not spin
   / Tires do not spin #61
Right now could be a fun time to submit all kinds of possibilities for our OP. . . . .sorry but the C-19 really brings out he animal in me.
   / Tires do not spin #62
FOR SALE: Guaranteed not to spin the tires in your local tractor pull.............
   / Tires do not spin #63
Took the fel off. And backhoe off . Chain to a tree. It will not spin.
Sum ting wong, Sounds like it's in high range and your trying to take off, but you say your in low range. I have the same machine with loaded tires and weight on the three pt. hitch and I'll still spin the AG tires. Possible error somewhere in drive train electronics or such.
   / Tires do not spin #64
I just recently had my Kioti do something similar... turned out that i needed to change the filter... 🤷‍♂️
   / Tires do not spin #65
My TC40DA HST with R4s will spin all 4 tires when I push into a dirt pile. Sounds like there is an issue.
   / Tires do not spin #66
Hopefully we will hear from the OP today. Maybe he has had time to do some more trouble shooting.
   / Tires do not spin #67
Got a ck3510 hst shouldn't this thing spin the tires when you go onto a pile of dirt or gravel
Does the CK3510 HST have a "stall guard" feature? I had a similar problem with my Kubota and discovered I had accidentally turned stall guard on and engine would die when I loaded it up. I am not familiar with Kioti product so I don't know if this might be issue.
I run beet juice ( rim guard ) in my M59 and have never had issue with tire spinning on the rim with 5 plus years of usage and thousands of hours of time. If the bead unseated and spun on the rim, I would expect to see some beet juice ( even a small amount ) visible on the rim.
   / Tires do not spin #68
I sent the OP a PM. We will see if he responds.
   / Tires do not spin #69
If in low range and at operating RPM with everything functioning normally, something is wrong. It should easily spin the tires.
   / Tires do not spin #70
The suspense is KILLING me. I have no opinion or advice but it's like someone tore the last 10 pages out of a Agatha Christie novel...Who Dun it?!?!
2015 GENIE S-60 MANLIFT (A58216)
2015 GENIE S-60...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
2014 Ford Escape SE SUV (A56859)
2014 Ford Escape...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A55973)
2015 Freightliner...
White Metal Roof Panels (A55758)
White Metal Roof...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56436)
2023 Kubota...
