Tires and tubes
/ Tires and tubes #1
SRF34
I just punctured my rear 13.6-16 Firestone 4 ply turf tire and tube and lost all the calcium chloride. Tire was punctured with 3 little holes. Fortunately I was able to limp it back to the shed and get everything washed and rinsed before I lost all pressure and fluid.
1) Any recommendations on whether I keep the tire and replace just the tube, replace tire and tube since I will refill with calcium. Tire is on a NH 1320, probably 16-17 yrs old.
2) If I go with new tires, any suggestions on brand/price?
/ Tires and tubes #2
If the tire(s) aren't worn out or dry rotted I'd just replace the tube. You should probably put a patch on the inside of the tire or plug the punctures to keep dirt from infiltrating the tire and causing problems. Just my opinion, tires aren't cheap.
M.D.
/ Tires and tubes #3
If the tire casings are still good why replace them? black rubber is $$$... just patcht he tire fromt he inside, and then path or repalce the tube..
soundguy
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
2002 Ford E-450 Enclosed Service Van (A59230)
2002 Ford E-450...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59905)
2020 INTERNATIONAL...
2012 Ford F-250 4x4 Pickup Truck (A60352)
2012 Ford F-250...
