Tire Width Stance
/ Tire Width Stance #11
Personally, I like to at least keep the centerline of the fronts equal to the rears or better still the outside edge of front and rear the same. It seems to help me when pulling beside something like a tree or fence line so I know if my fronts don't hit then the rear is good to go. Stability wise, widening the fronts doesn't help as much as widening the rear because the fronts do float a bit till they bottom out on the frame stop. At least from the photo, you can adjust the front out a couple more inches if you want by swapping sides with the front tires to more equalize the tread width.
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A61307)
PENDING SELLER...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
