tire repair?
/ tire repair? #1
ch1ch2
DFW, TX
IH 584, NH TC33DA, NH TN95A
I know tires can be recapped, but when should you do it and when should you just buy new?
Additional question...
I ran over something and blew out a tire and tube. I took it to the repair shop and they put a big patch in the tire and a new tube. It has been about a year now and I just noticed that the hole is opening up. It is about 2 inches wide at its widest and is about 6 to 8 inches long. Can the tire be saved?
/ tire repair? #2
The tire could be foam filled but with a 2" x 8" opening in the tread it seems like the belts inside the tire are gone and it probably should be replaced.
/ tire repair? #3
You don't indicate what the tire is on, but if its 2" x 8" - I think its time to replace the tire.
/ tire repair?
It is a R1 24 in front tire on a 90 hp NH 4WD with FEL.
I can not see any sign of belts inside. It looks like solid rubber. (not suggesting that it is solid rubber)
/ tire repair? #5
We used to use farm tractors for logging. cut the side walls and punctured many a tractor tire on a stomp or stobb. we would take a drill and drill laceing holes along the cuts and use baleing wire to lace them back up. Put a piece of old intertube inside over the lace wire and go back to work. Poor folks have poor ways and you did what you had to do.
/ tire repair? #6
We used to be able to vulcanize a split like that with new rubber and the tire would look like new. I doubt you could find a place that does that any more. If you have a recap place they may be able to help you, otherwise, I think you are going to have to buy a new tire.
/ tire repair? #7
Take a picture.
If it lasted a year... A little better repair might be just the thing.
Look for a company that repairs heavy equipment tires
/ tire repair? #8
Since this thread is in the welding forum,,,
I would try to weld the tire,,, get the New MILLER BOBCAT CUTIRE 200 welder,,
what shielding gas is required? :confused:
:laughing:
/ tire repair? #9
I think it is time to scrap the tire and get a new one, at least new to you. The scrap tire can be used as a flower pot.
/ tire repair? #10
:laughing:
Thanks for posting. I was racking my brain trying to understand the association between a flat tire and melting metal. Now I know where to start.
/ tire repair?
:laughing:
Now how the He** did that happen?
I know I clicked on tires and new thread!
But maybe your on to something...Is there a MILLER BOBCAT CUTIRE 200 Vulcanizer? Or maybe a blow torch vulcanizer?
/ tire repair? #13
The rubber used in new tractor tires just is not as tough as it used to be. Back when I was a builder, my dad had a Pettibone forklift. I would say the rear tires were 30 years old and had cracks large enough that I could slide my fingers in, but in the 15 years we owned that machine, those tires never went flat.
/ tire repair?
Looks like I will replacing it.
/ tire repair? #15
It depends on where the cut is,,, but,,,
I have seen an AG tire have 1/8" holes drilled 1/2" from the slice,,
then, you simply "sew" the cut closed with stainless steel wire.
That held when I had my hernia operation,, I doubt your tractor could strain the tire any harder,,, :eek:
:laughing:
Kawasaki STX-12F (A64127)
Kawasaki STX-12F...
Western 8.5 Pro Plus Ultra Mount (A62679)
Western 8.5 Pro...
(APPROX. 29) ASSORTED ROUGH SAWN PINE (A64276)
(APPROX. 29)...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
Bandit 250XP Wood Chipper (A63689)
Bandit 250XP Wood...
