tire repair?
/ tire repair? #1
ch1ch2
DFW, TX
IH 584, NH TC33DA, NH TN95A
I know tires can be recapped, but when should you do it and when should you just buy new?
Additional question...
I ran over something and blew out a tire and tube. I took it to the repair shop and they put a big patch in the tire and a new tube. It has been about a year now and I just noticed that the hole is opening up. It is about 2 inches wide at its widest and is about 6 to 8 inches long. Can the tire be saved?
/ tire repair? #2
The tire could be foam filled but with a 2" x 8" opening in the tread it seems like the belts inside the tire are gone and it probably should be replaced.
/ tire repair? #3
You don't indicate what the tire is on, but if its 2" x 8" - I think its time to replace the tire.
/ tire repair?
It is a R1 24 in front tire on a 90 hp NH 4WD with FEL.
I can not see any sign of belts inside. It looks like solid rubber. (not suggesting that it is solid rubber)
/ tire repair? #5
We used to use farm tractors for logging. cut the side walls and punctured many a tractor tire on a stomp or stobb. we would take a drill and drill laceing holes along the cuts and use baleing wire to lace them back up. Put a piece of old intertube inside over the lace wire and go back to work. Poor folks have poor ways and you did what you had to do.
/ tire repair? #6
We used to be able to vulcanize a split like that with new rubber and the tire would look like new. I doubt you could find a place that does that any more. If you have a recap place they may be able to help you, otherwise, I think you are going to have to buy a new tire.
/ tire repair? #7
Take a picture.
If it lasted a year... A little better repair might be just the thing.
Look for a company that repairs heavy equipment tires
/ tire repair? #8
Since this thread is in the welding forum,,,
I would try to weld the tire,,, get the New MILLER BOBCAT CUTIRE 200 welder,,
what shielding gas is required? :confused:
:laughing:
/ tire repair? #9
I think it is time to scrap the tire and get a new one, at least new to you. The scrap tire can be used as a flower pot.
/ tire repair? #10
:laughing:
Thanks for posting. I was racking my brain trying to understand the association between a flat tire and melting metal. Now I know where to start.
/ tire repair?
:laughing:
Now how the He** did that happen?
I know I clicked on tires and new thread!
But maybe your on to something...Is there a MILLER BOBCAT CUTIRE 200 Vulcanizer? Or maybe a blow torch vulcanizer?
/ tire repair? #13
The rubber used in new tractor tires just is not as tough as it used to be. Back when I was a builder, my dad had a Pettibone forklift. I would say the rear tires were 30 years old and had cracks large enough that I could slide my fingers in, but in the 15 years we owned that machine, those tires never went flat.
/ tire repair?
Looks like I will replacing it.
/ tire repair? #15
It depends on where the cut is,,, but,,,
I have seen an AG tire have 1/8" holes drilled 1/2" from the slice,,
then, you simply "sew" the cut closed with stainless steel wire.
That held when I had my hernia operation,, I doubt your tractor could strain the tire any harder,,, :eek:
:laughing:
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
UNUSED ATSPOWER STAND-ON SKID STEER (A64280)
UNUSED ATSPOWER...
1999 John Deere 7810 (A60462)
1999 John Deere...
2013 Nissan NV2500HD Cargo Van (A61573)
2013 Nissan...
2012 Mini Cooper Coupe (A61574)
2012 Mini Cooper...
