tire prices
/ tire prices #1
kramarj
Durand, Illinois
Kubota B7100 w/1630C Loader
does anybody know any good websites to price tires for a compact tractor? thanks
/ tire prices #3
One advantage of using a local tire service, is they will come to your farm...and do ALL of the work...:D
/ tire prices
well, my tires are small, i can just take the tires and rims to dealer right?
/ tire prices #5
Not necessarily. Tire machines will work up to a certain designed size limit. A place that only sells car tires may not be able to mount your rear tractor tires unless they do it by hand and the personnel may not have the skills or tools for the job -- there is risk of damage to the bead area or the rim if you just try to force the tire on with a crowbar and hammer or something.
If they do sell tractor tires, they may not want to mount tires you bought elsewhere without charging you a nice price for the service.
/ tire prices #6
Most major tire wholesalers will carry a dealer locator. Goodyear and Titan both had locators when I bought my tires for my CUT.
JD 770 / 70 FEL / 7 BH - 425 AWS / 54" MMM / 54" FMP
/ tire prices #7
I put a rear tire on our Farmall Super C once, well twice. Only took me a half a day, then I realized the tread was going the wrong way and got to do it over. JC
/ tire prices #8
I went online and searched around when I was looking for tires. I could find better prices then Les Schwab but with shipping it ended up about the same. Then you still need to get them mounted. So I ended up with Les Schwab doing the work. It took them 2 weeks to get the new tires in mounted and foam filled. They said it took an extra week because they ordered the Goodyears first instead of the Titans. $1100 for two 9.5x16" Ag tires mounted and foam filled
/ tire prices
i was talking about taking my rims and tires i have on now to a farm tire store and just buying them there and then have them put them on
/ tire prices #10
I did just that when I bought my tires. I searched Goodyear and Titan for the exact R4s for my rims......found a dealer on their site....then I jacked up my tractor and blocked it and rolled the rims with the old tires in the back of my truck. I went to the dealer and he drained out the fluid, removed and disposed of the old tires and mounted the new ones. I ended up paying a little more due to some scale issues inside the old rims that they had to repair and I also added tubes. Good Luck!
/ tire prices #11
When I had to replace the Titan tires on the front of my CK30 I phoned around and everyone else wanted $150 ea. and up, got 'em from Les for $96 ea. I bought 4, two new on tractor and two on hand. And to mount them "small" tires your self is a PITA, I know!
/ tire prices
another question i have is, are the r4 tires good in snow, or what is the best tire for snow and for tilling gardens, that is what i mainly use my tractor for
/ tire prices #13
Hey, thanks for making my case...:D
/ tire prices #14
When I replaced my tires I went from AG R1s to Industrial tread R4s because any where I go from my garage I am on my lawn. I use my tractor on my lawn for landscaping and also for heavier work out in the field. The R4s are not as destructive to my lawn and are aggressive enough to go out in high grass or mud. I have had zero problems with traction. Now let me clarify that statement.......my CUT is MWFD and that helps in the winter time and soft conditions. If I did not have to be careful where I go I would own Ag R1s for price and traction. In my opinion it all depends on the surface you are on.
/ tire prices #15
Look at Dublin Wholesale Tire in Dublin, Ga (dublinwholesaletire.com) they have an ad in Fastline, SE Farm Edition this month, with prices.
/ tire prices
thank you guys for all of the info, it was really helpful
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2014 JAYCO JAYFEATHER TRAVEL TRAILER (A63569)
2014 JAYCO...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
2021 CAM P3612TT 6x12 Utility Trailer (A64047)
2021 CAM P3612TT...
2018 MACK CXU (PINNACLE) (A63569)
2018 MACK CXU...
