Tires Tire Pressures
/ Tire Pressures #1
317140
Bronze Member
North Carolina
John Deere 3520
I had my 3520 out yesterday to clean up dead tree limbs and trash since we had such a nice day. It was in the high 50s. When I took it out of the shed I noticed I had a low tire on the front. I got out my small compressor and proceded to air up the tire. I looked all over the tire to find the correct inflation pressure. I had no luck. It has r4s and it has a front loader. I've never seen a tire that didn't have a pressure stamped on the side. Need some help. The tire on the other side showed 30psi so I aired the other one the same. I just wanted to know if this was enough pressure to run with the loader on. Also the tires showed some dry rot cracks on the sidewall. The tractor is a 2006 with 223hrs. I was wondering if anyone has experienced the same thing. Thanks for info.
/ Tire Pressures #2
That's odd, the online 3520's manual says "see specifications" for tire pressure but this info is not included in the specs. I had no problem finding correct pressure for my 4720 but JD appears to have forgotten to provide it for the 3520. :confused:
If it's any indication front tire pressure specs on my machine have a very wide range, something like "between 25psi and 45psi" for the type of tire I use. Obviously the wide gap indicates pressure should be adapted to load.
/ Tire Pressures #4
Page 89 in the owners manual list the tire specs.
/ Tire Pressures #5
Well thanks for that deere link,I got a post going in both kioti and on kabota forums about this,that was just what I was wanting.
/ Tire Pressures
Thanks for the information. I was sure the tire pressure would be stamped on the sidewall. I didn't think to check my manual. Lots of good information in there that I had forgotten about. It's still good to have this site to keep me on my toes. Thanks
/ Tire Pressures #7
It's dark and cold outside tonight so I can't be sure, but I had a low front one the other week and the only thing stamped on mine was not to exceed 32 or 35 psi when seating the beads. So I just keep mine at 30. Any less and they squat pretty bad when the bucket is full of dirt/rock.
2015 JOHN DEERE 544K WHEEL LOADER (A65056)
2015 JOHN DEERE...
2018 CHEVROLET SILVERADO CREW CAB PICKUP TRUCK (A66091)
2018 CHEVROLET...
2013 RANCO BELLY DUMP (A67714)
2013 RANCO BELLY...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A66736)
2018 Ram 1500 4x4...
2002 SUPERLINE DO20T242LP T/A 24FT TRAILER (A66091)
2002 SUPERLINE...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
