Tire pressure question
/ Tire pressure question #11
I run Es on my truck and trailers. Summer is different than winter. I don't fill to 80 because I know they will heat up.
You dont wanna do that.. They will get hotter with the lower temps. You want to minimize the sidewall flexing (which is the major cause of heat) as much as possible while still having a good contact patch. If you lower the pressure thinking they 'will heat up anyways', you are increasing the sidewall flex and thus heating them up even more than if you had aired them up. Tires can take over pressure and the OEMs make allowances for it. They cannot take excessive heat.
/ Tire pressure question #12
Midnite is correct. The only thing i would add is to fill the E rated tires to 80psi cold regardless the current/expected ambient air temperature.
/ Tire pressure question #13
Looking for answers from the pro's on this.
OK, got some new Duravis tires for the 5th wheel, and so far love them. I do have a question regarding OFFICIAL opinions on tire pressures.
Here's the story.
Before we left our area (hot...90+) I checked all 4 tires, sitting right at 80 PSI (MAX Cold rating). OK All is Good. We drove to the camp site 2.5 hrs away, up north at the coast, and camped for several days. Temps there in 50's and 60's (yea we LOVE IT). Today before leaving I checked pressures again (temp is 60 deg F) and all 4 pressures right at 70 PSI. Now I know colder temps mean lower pressures, but 10 PSI seems like a lot. The tires do NOT leak. I have had them sunk in tanks to verify. They are brand new Duravis R250's, 235/85R16's that are ALL steel plys, very heavy duty tire.
I aired the tires back to 80 PSI at the 60 deg temp (mistake?)
When I got home from the trip I tested them again (temp 100deg F) and all 4 are at 90 PSI.
SO they were 80 before taking off, 70 after 3 days in cool weather, aired back to 80 and show 90 after travel in very hot weather.
Am I doing something wrong? I got home too late to call tire shop, but will call them tomorrow to get their input as well.
Normal, that is why the sidewall is stamped with psi cold . There are other higher priority items in this world to worry about.
They taught all about the universal gas law in high school .
/ Tire pressure question #15
+1
Check when cold and fill to 80, they are designed that they will heat up and have higher pressure.
/ Tire pressure question #16
What he said.
I always check my 5th wheel tires cold, never worry about them other than a visual check at every fuel stop.
/ Tire pressure question #17
On longer trips with a trailer I touch each hub and tire with my finger at fuel stops. You can feel if something is heating up compared to the others. Takes less than a minute.
/ Tire pressure question #18
Should see if Tom Brady has a theory on this I'm sure he knows all about "inflate" "deflate" and ambient temps.
/ Tire pressure question #19
80 psi cold. Don't even bother checking them when hot from driving. I check my tires before I tow and set them to 80 regardless if it is 20 degrees or 100 degrees outside.
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
2016 CATERPILLAR 930M WHEEL LOADER (A62129)
2016 CATERPILLAR...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
Engine (A59228)
Engine (A59228)
