Tire Pressure B7800?
   / Tire Pressure B7800? #1
CMRVA
Richmond, VA
Kunota B7800 (2004)
Sort of a neo-phyte here. My front tires (Ag type) look to me like they are extremely soft (really a lot of play when driving uphill, making turns, etc.) and I was wondering how much air should be in the front and back, and if there is a tip for eyeballing correct pressure. Thanks
   / Tire Pressure B7800? #2
Look in your owners manual. The tire pressure ranges should be listed.
Tire pressure gauges can be had for a few bucks. I wouldn't trust the eyeball myself.
The fronts are usually higher. I run 18 in the rear and 23 in the front of my L3400.
   / Tire Pressure B7800? #3
On edit: Sorry I just noticed you mentioned Ag tires in your post. Please disregard the inflation #'s. Maybe you can use some of the other info???
Recommended pressures are: 22psi front, 16psi rear for R-4 tires.
Normally I run the above inflation, however right now we are entering "mud season" around here so I have dropped to 12psi in the rear and may go down to ten for a wider footprint. Next "dust season" I might just leave them at the lower rear pressure since it makes a noticeable difference in ride comfort. We'll see???
A good tip I learned on TBN is to swap the fronts from left to right (or whatever) thus reversing the rim offset. Gives an additional 5" +/- of front tread width which really helps the stability on a B-7800. Downside is the tires will now have to be inflated on the inside of the rim. Acceptable trade off IMHO.
Good luck
1995 Ford Water Truck (NOT RUNNING)(TITLE) (A50774)
1995 Ford Water...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
New Paladin Tag Quick Coupler (A50774)
New Paladin Tag...
INSPECTION (A51572)
INSPECTION (A51572)
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2011 Bobcat S630 Skidloader (RIDE AND DRIVE) (A50774)
2011 Bobcat S630...
