Tire loading adapter?
/ Tire loading adapter? #21
I thank you I thank you I thank you!!!!!
I will be at Napa tomorow AM!
I stopped at the local Tractor place last night. They had one made by Milton.
Milton part #s466. Priced at $7.59.
I have several of their air-tool products - Good Stuff.
Local Car Quest quoted me 13 bucks and change when I asked while purchasing a widget to remove the valve cores (they stock Milton products).
Kit looks exactly like the one in the NAPA Online photo. Seems to be well made.
Good luck!
/ Tire loading adapter? #22
What the high I.Q sales people at TSC did not tell you is they now stock one made by SLIME -- I had the same experience last spring until I found a guy in the store who had an I.Q larger than his hat size and he told me that the Monkey grip number was replaced by a Slime number but he did not have any way to find the number -- we then went back to the section of slime stuff he had just stocked and -- guess what -- there it was:p:p.
And yeah -- it was not 100% successful as they say in the military
/ Tire loading adapter? #23
Well,
I get to find out how it works tonight, as I finally have a night off (from 2nd Job), and will have a few hours to play in the pole-shed. I imagine that TSC will be calling me in the next couple days to let me know they finally have the kit back in stock. Too bad I'll be saying thanks, but no thanks.:rolleyes:
I got mine from Napa yesterday, it was $17.00, it is a quality adapter.
Now I have to find windshield washer fluid on sale!
Thanks Bob
/ Tire loading adapter? #25
Done!
Each tire took 42 Gallons, and 2.5 hours to complete. Luckily the Pole-Shed needed cleaning / organizing before the snow flies, so I had something to do whilst I was waiting.
I won't know the difference in "feel" until tomorrow night (gotta work 2nd job tonight).
After finishing the fill, I aired the tires to 15 psi, same as before the fluid.
Any thoughts on that pressure???
Thanks,
Lunk
Hey Lunk,
I have a Branson 4720, I think it has the same tires as yours. I looked at a web sight about filling tires and it said they should take 35gal each, How far did you fill yours? or where did you put the stem when filling? it sounds like I may need 90 gals, not 70.
Also what did you fill with? did you get it on sale?
Thanks Bob
/ Tire loading adapter? #27
Hey Lunk,
Thanks Bob
Bob,
My rear tires are, If I remember correctly, 43x16x20's.
I had the valve stem at 12:00 (AM or PM - it don't matter ;))
When I asked here on TBN how much they thought it'd take - An educated guess was about 50 gal. I did jack the tractor up fairly high to tilt the wheel back away from the valve stem, which may have helped with the extra gallonage.
I just filled them until the air-release valve would only release fluid, indicating that the level had been reached.
I used Zecol Blast WW Fluid. It was on sale for $1.39 per gal at the local Farm & Fleet. It was supposed to be the -25 stuff, but surprise-surprise, the online ad was wrong - It was -20 rated. They wouldn't knock anything off though, and as a businessman, I cannot stand the folks who cry "False Advertising" at every turn, so I accepted the deal, as it was still about 50 cents cheaper than other -20 stuff, and was an actual name-brand product to boot.
I'm confident it will do just fine...
How many hours on your 4720?
Has it been a good ownership experience thus far?
Thanks, Lunk
$1.39 !!! Thats great! the best I can do is $1.99. I will keep looking, I will also check my tire size and confirm it is the same.
My Branson experience has been great! I have about 100 hours on it, and it has worked hard for most of them. It does not have the power on my JD 310, but I also didn't expect it to. It is a stout machine. I would buy it again. How about you?
Bob
/ Tire loading adapter? #29
My previous Tractors have been pretty basic. No PS, No live PTO, No shuttle shift, No diesel power, No decent loader or FWA...
How do you think I like it?
Fact is I love it. I think I'll at least double annual the hours I used to put on, just because I enjoy using it so much. You end up going out of the way to do "projects" that before were just a PIA, and you didn't want to tackle unless absolutely necessary.
Only 42 hours. So far - So good!
I must say though that our forum section sucks big-time. Not many of the world's problems being solved there...
I enjoy the cat-fights that crop on TBN re: drive type, tranny choice, tires, etc. Apparently everyone makes different decisions based upon their needs, and no one is ever wrong in the ones they make. Sounds like a perfect world to me:D
/ Tire loading adapter? #30
Thanks Bob[/QUOTE
The fitting from NAPA is made by Schrader-Bridgeport, and is a quality product, and along with it's main competition, Milton, still produces the majority of it's products in the USA.
As for the W/W fluid, if you live in what is known as an EPA "non attainment area", the fluid is only good to only +20F due to a cap of 8% methanol. Any sold in these areas that has a lower freeze point have other chemicals to prevent freezing; usually glycol, which would not be bad, except I have to sometimes throw out some half full jugs of W/W fluid because they have an algae, or some king of stringy slime growing in it, and has a slightly foul odor. I have also had to remove and dump/rinse my washer tank on one of my trucks for the same reason. It take about 3+ months before the slime forms, and only in jugs that are less than 75% full. I would try to find out where the folks making bio-diesel are getting there methanol from.
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
1761 (A58375)
1761 (A58375)
2012 International 4300 Reefer Truck (A61307)
2012 International...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
INOP/NON-RUNNING 2012 Jaguar XJ Passenger Car, VIN # SAJWA2GE5CMV37496 (A61165)
INOP/NON-RUNNING...
