tire keeps going flat
   / tire keeps going flat #1
vulcan101
alabama
kubota L2800
have a l2800 with 7x16 front tires and one of them keeps leaking down..nothing in the tire and have tried sealing with dawn soap around the edges but once a week it goes down.is there a better way to stop this than having to put in a tube.
   / tire keeps going flat #2
Many many threads on this...
I had the problem on the front left of my new BX2660. Every week I had to fill it. Took it once to a tire shop, they cleaned the rim, and rebeaded it. Didn't last. Finally put a tube in it and it has lasted all summer without the need to add air. Hopefully on my property I won't puncture it because then a fix is much more difficult than a tubeless. The other front is still tubeless and working great.
   / tire keeps going flat #3
Just had to replace my left front tire and wheel on my BX2660. I told Davis Farm Supply of my problem and they gave me one free of charge.
   / tire keeps going flat #4
My front tires always leaked since purchase, left more so than the right. But I put a container of Slime in each and have not had a problem for a little over a year now.
   / tire keeps going flat #5
Agree with BotaBX24er....SLIME!!:D
Deano
   / tire keeps going flat #6
Out of 4 BX's purchased 3 have had this same problem. One tire slow leaks and now my Spring purchased BX2660 is doing it. One I had a tube installed and the other I just traded off. May try Sliming this one.
   / tire keeps going flat #7
I put slime in my fronts and end of problem...
I had the rears foamed filled because too many weekend projects were interrupted by flats...
I also bought a spare set of tires and rims and have not had a single problem since...
   / tire keeps going flat #8
Ditto on the sealant for my front right tire. No problems since.
Cheers,
   / tire keeps going flat #9
Foam filling the front tires works well too. But if you do have them filled buy a new set of tires before you fill them. no since in spending the money to fill half tread tires.
   / tire keeps going flat #10
Add me to the long list of "Slimers" I wouldn't be with out it
and the front's are the worst in my opinion.
tom
Tool Box (A47384)
Tool Box (A47384)
JOHN DEERE 3032E TRACTOR (A51243)
JOHN DEERE 3032E...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
NORTHERN 3P-100 AG MIST SPRAYER (A51243)
NORTHERN 3P-100 AG...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
Single IH Suitcase Weight (A50515)
Single IH Suitcase...
