Tires TIRE INFLATION PRESSURE
/ TIRE INFLATION PRESSURE #1
grsr3
Bronze Member
What is the correct pressure for these tires and what do the letters and numbers mean:
Fronts- Tai Shan---6:00/16---R-I---Nylon---6PR---Rim-4.50E
Rear- Teng Jiang---9.50/24---R-I---Nylon---8PR---Rim-W8
George
/ TIRE INFLATION PRESSURE #2
George
Not sure the proper inflation pressure. Give a look at the sidewall of the tires and you should find it there.
Tire ID:
tire cross section/rim dia (inches) ---?-?---cord material---layers of cord (ply rating)---rim width.
On ply rating, it may not be actual layers of cord. It did represent layers many yrs ago but with improved materials there are fewer layers today but with same strength as the older actual plies.
/ TIRE INFLATION PRESSURE #3
GRSR3,
This may help you.
Tire inflation pressure,
front ag tire 6.00 X 16 26 to 29 psi
rear ag tire 9.50 X 24 15.5 to 17.5 psi
These are specs for the ag tires on my 284LE.
corey
INFO LOT (A64047)
INFO LOT (A64047)
2018 International HX620 Quint Dump (A62613)
2018 International...
Kubota Snow plow with subframe
Kubota Snow plow...
2021 CAM P4EC16  16ft 8000lb Trailer w/ Ramps (A64047)
2021 CAM P4EC16...
Rake Mini Excavator Attachment (A61572)
Rake Mini...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
