Tire Failures
/ Tire Failures #1
Mark Page
Platinum Member
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
I have a 7 ft. Woods finish mower that I pull with a 45 hp Massey. The whole rig is about 8 years old and does a great job.
Starting last year I've been having problems with tires going flat on the mower. I replaced 4 inner tubes last year and 2 so far this year. I went so far as to buy a a spare tire and wheel assembly so I didn't have to stop and run to my dealer each time it occured.
It's never the same wheel and the tires look like new. The problem is with the inner tubes. They only go flat while I'm moving and by the time I catch it the tube is shredded. There is never any visible penetration of the the tire.
I can buy new solid tires and wheels for $160, but you have to replace the yokes to the tune of $400.
No one seems to have an answer to this problem. I've tried fix a flat without results. I'm thinking about sliming them.
What say ye?
/ Tire Failures #2
could you have thorns in them? mount them tubeless to use slime .
/ Tire Failures #3
A friend of mine, had his tires foamed.
/ Tire Failures #4
It seems like I've bought way too many new tubes and tires for my ATH 720 Bush Hog. It cost me over a hundred bucks to throw away the crummy bushings and put in ball bearings and I made everything except the bearings. So, I'm pretty wedded to the 4.00 X 8 tires. I keep the pressure at max, and I hate to say it, but no flats so far this year. The stem hole positions in the tires almost make me pinch the tubes. Foam sounds good.
/ Tire Failures
Can't find anyone within 100 miles that foams tires. Should I be talking to people who deal with industrial equipment? Maybe a forklift dealer.
/ Tire Failures #7
I don't know much about the process.
From this site.
"Urethane foam can be substituted for air in a tractor tire. Foam is available in several densities which approximate different inflation pressures. Once the foam sets, the tire is truly puncture proof. This is popular with construction equipment, but useful for small tractors, as well. It is expensive: $40 or more for a small tire. Foam-filled tires are several times heavier than air-filled tires. Foam-filled tires are harder on a tractor's steering mechanism than air-filled tires, since there is less "give" to the foam. For the same reason, foam-filled tires tend to create dents and ruts in the ground. Finally, foam filling does not make a thin tire stronger; in fact, it may put more stress on a light duty tire than it was designed to withstand -- resulting in a shredded tire with nothing to support the foam. So, this process is recommended only for heavy duty tires. Most industrial tire dealers provide this service."
/ Tire Failures #8
Foam 'em.....Find a dealer who sells/services skid steers, back hoes, industrial equipment. Foamed skid steer tires are VERY common.
Knowing where you live, someone might be able to steer you in the right direction.
Also, tire/wheel assemblies for certain applications are available through a number of sources. They'll already be foam filled.
I run foamed used aircraft tires on my bat wing mowers.
Flat Proofing, Liquid Tire Sealant, Foam Fill Tires - Ken Jones Tires
/ Tire Failures #9
We also run foam filled aircraft tires on our 10' Woods; it was an option when we bought it.
/ Tire Failures #10
I've had lots of problems w. tires on a finish mower ...in my case from sideways pressure on the sidewall that unseats the tire ...it helps to make sure the spindles (kingpins?) are well lubed and that the tire pressure is high. A little slower speed is gentler on the tires, especially if there are some ruts in the ground. Finally, I often have a problem if I try and turn too sharply or, worse, try and back up ...the caster sometimes doesn't do what it's supposed to and stresses the tire. ...if you frequently make sharp turns or, worse, "three-point" turns then consider lifting the mower a tad (but not so high that you are running the universals on your drive shaft at a steep angle.
Don't understand the need to change out the forks to go w. solid tires ...that might be true for the woods solids, but google marathon tires and see if there isn't one that is sized to fit ...and, they are modestly priced.
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
5004 (A55851)
5004 (A55851)
2012 FORD F-250 (INOPERABLE) (A60736)
2012 FORD F-250...
20' DOUBLE AXLE INDUSTRIAL TRAILER (A59823)
20' DOUBLE AXLE...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
Bobcat T590 (A53317)
