Chains Tire Chains
/ Tire Chains #1
Anonymous Poster
Epic Contributor
Before I get to the question I want to thank all of you. I bought a BX2200 in august and have been happy since. My question is...Does anyone use tire chains when they're plowing snow?
/ Tire Chains #3
My driveway is 300 feet of blacktop and is fairly steep. I use chains on all 4 wheels. ...makes a terrific improvement!
Peter
/ Tire Chains #4
Take a look at this link Tire Chains. I just ordered mine today and I provided a link to the company's URL.
Hope this helps.
Terry
/ Tire Chains #5
I use the duo grip chains on the rear tires only. Well worth the cost. (Just put them on yesterday - must be why we're at 70 deg today!!!) /w3tcompact/icons/smile.gif
/ Tire Chains #6
Oh, you guys have this wonderful fall weather also....
When is the hammer going to drop and we see winter?? /w3tcompact/icons/blush.gif
Since I bought chains for front and back, I know exactly how much snoe we're going to get. Little to none!! /w3tcompact/icons/wink.gif/w3tcompact/icons/laugh.gif
Terry
/ Tire Chains #7
If that's true let me thank you in advance! I don't mind plowing every now and them but last winter it did get a little tiresome plowing every day for a week at times!
/ Tire Chains #8
I have a new asphalt driveway that I put in in the spring. Will chains damage the surface? I have a BX with turfs, and I plan on using it for snow, both with FEL and 60" rear blade...any experience, folks? Think I'll need em? My drive is only about 180' and fairly level, with only a slight drop at the road.
/ Tire Chains #9
i live in western new york, we get lots of snow. i don't have chains, my drive is only about 100 ft and level, so 4wd is fine for me.to ans. charliebern, if u slip them chains they will tear up the driveway. guess it just depends on your situation. but chains are a big help. could not have lived without them when i had the old ford 8n.
/ Tire Chains #10
Jon - as others have said, if your place is flat you may not NEED chains - but they sure are nice.
My place has very few flat areas so my rig has chains all around. Helps a lot - especially in deep snow or on icy pavement. Once last winter we had a coat of new ice on our road and it was raining hard - the only way anybody could get safely down the hill was tethered to my all-chains Kubota, sorta like reverse towing, while I slowly let them down the hill. (our road crew was a little slow getting out here that night)
Chains are good.
/ Tire Chains
Thanks Terry, I checked out Tire Chains. A set for my BX2200 (front and back) will cost about $200 including shipping. Now I know what I want for Christmas!
P.S. How did you include the link into your post?
/ Tire Chains #12
"I have a new asphalt driveway that I put in in the spring. Will chains damage the surface? "
Charlie;
Depends on the type of chains that you get. I see that some chains can be really aggressive and basically have daggers on the ends!
I'm in the same situation as you; I just backtopped my gravel driveway this summer. I also bought ladder style chains for my B7500 rear tires this summer.
I've tested them out a few times on the driveway to see if they would do any damage - absolutely no markings or indentations whatsoever. I had my front blower and rear blade on when I did it (one reason was because was bored - no mowing to do and it's too muddy to do any FEL work, so I start it up every weekend and drive it around a bit just it's not sitting).
I got chains for my rears this year because last year, my first winter with the B7500, I would have side slipping problems. My father in law has a Yanmar and uses chains, and he recommended that I put them on, so I bought some. I didn't have the rear blade last year, which would have helped with the additional weight on the back.
/ Tire Chains #13
When I was younger we had a CASE tractor that we would mount chains on for plowing. The bottom 1/3 of our driveway was blacktop and was extremely steep. The only way we could get up was to spin the heck out of the tires until we hit the cement portion which also leveled out a bit(no 4wd). This never did any real damage to the driveway other that some scratch marks which were purely cosmetic and were taken care of with resealing in the spring.
Jeff
/ Tire Chains #14
I use "chains" made with rubber belting cleats that do not leave any scratches or marks on asphalt driveways. I use them on both the front and the rear of my JD 955. I ordered them from Dave Anderson, Deere Creek Equipment, Oxford, PA, 1-800-255-6567. I have used them 2 seasons and am very pleased with performance.
/ Tire Chains #15
JonCat,
You can get to the info two ways. Either by clicking on the FAQ link at the top of each page or by clicking on the link under the "Reply to (xxxxxxxxxx)" header. The text looks as follows:
<font color=blue>Fill out the form below to post a message on the forum. HTML is disabled. Markup is enabled, so you may use <font color=green>markup in your posts</font color=green>. </font color=blue> Just click on the link shown in green. FYI, it helps a little to understand HTML. If you don't, not to worry. Just follow the instructions and experiment. Muhammad gave us extra chances by allowing you to edit your posts prior to posting them. I'm not all that smart and learned how to use the stuff quickly.
Hope this helps.
JackIl,
What did you use to make your rubber covers?
Nice picture of you blowing snow! /w3tcompact/icons/smile.gif That looks like fun!
Terry
<P ID="edit"><FONT SIZE=-1>Edited by TerryinMD on 11/20/01 12:31 PM (server time).</FONT></P>
/ Tire Chains #16
Terry,
I did not make any "rubber covers." These chains are commercially available and are made with lateral strips of heavy duty belting connected to a circumferential metal chain on each side. You simply specify to tire sizes when ordering these "chains." They prevent scratching and marring asphalt or concrete surfaces.
/ Tire Chains #17
I use chains on my deere garden tractor and snow blower, and on my B2910 and snow blower. They are a big help in both cases. Only the little Deere runs on asphalt and I haven't had any trouble with road surface damage, but do watch out for the chains that have cleats on them as I suspect they would eat away at the surface. My chains in both cases are just plain link chains.
When you buy chains, don't be surprised if you need to cut them down. This is not at all uncommon, but has been a source of surprise and disppointment to a number of people who were expecting to get exact fit chains.
Peter
2019 CIMC 40ft. 36 Ton T/A Container Trailer (A64556)
2019 CIMC 40ft. 36...
2025 Miscellaneous Mini Excavator Attachments (A64553)
2025 Miscellaneous...
1995 FORD F-SERIES S/A GRAIN TRUCK (A64278)
1995 FORD F-SERIES...
2018 CATERPILLAR CB10 DOUBLE DRUM ROLLER (A65053)
2018 CATERPILLAR...
2011 Kenworth T400 33Yd. Side Loader Garbage Truck (A64194)
2011 Kenworth T400...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
