Tires Tire chain?
/ Tire chain? #1
arksdad
PA
IH656 - NH T2310 - Country Clipper 60" ZTR
My new T2310 has just arrived. I want to put a set of chains on it for winter. There's not much clearance between the tire and fender. I'm wondering if anyone out there has put chains on this model [2310,2320,3040,3045,TC40A,TC45A] and if the fender clearance has been a problem?
/ Tire chain? #2
I had to remove the inner rear wheel splash guards on my TC40S to mount some fairly heavy chains. They would just not clear the guards without rubbing. I didn't want to turn my wheels to the wide mount position because they would be outside my bucket edges. Not good for snow clearing.
Dave.
/ Tire chain? #3
I had a 1710 with turf tires which had little clearance. The chains I used on that rig were not really heavy and I had to keep them tight to clear everything. Bungee cords can help keep slack out of them.
/ Tire chain? #4
My factory tires had a label on them as to which side faced the tractor, so i did not think the rims could be flipped. Since there was some different offset if they were flipped I had enough room for the chains. I had to scour the manual and there was a section that said that you could flip the tires. So I flipped 'em and pur my heavy duty chains on with plenty of room to the fenders.
Maybe read the manual really thoroughly of call the dealer and ask.
CAT Chassis Only (A59076)
CAT Chassis Only...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2006 KENWORTH W900 (A60736)
2006 KENWORTH W900...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
2005 Ford Freestar Van (A59231)
2005 Ford Freestar...
UNUSED FUTURE 32"...
