TIRE BOLT SIZE
/ TIRE BOLT SIZE #1
ADAME2M
Wilmington, CA
KUBOTA L245DT
Hi there!!!
Can anyboby help me.
I own a KUBOTA L245DT LATE 70'S. I want to fing out the size of the nuts and bolts to remove the rear wheels. I want to buy the correct sockit for it.
I have to move the rear wheel tread, but I need to drive 2hr to get to my tractor, and I want to go ready with what I need.
If any body could help me.
Thank you.
/ TIRE BOLT SIZE #2
The bolt/stud size is 16mm the head of the bolt/nut will be 22 and/or 24mm.
/ TIRE BOLT SIZE
Thank you for your help!!
so the size of the nuts on the hub are 16mm? connects to the differential
and the size of the nut on the rim are 22 or 24mm? connects to the tire
I need both sizes in case I only need to remove the wheel or the wheel and the rim.
Thank you again!
/ TIRE BOLT SIZE #4
No, I was giving you the proper terminology. Nut, bolt, and stud sizes are given by their diameter not by the head size. 16mm nuts and bolts will have either a 22 or 24mm head. Kubota uses both, the bolts will likely have a 22mm head and the nuts will have 24mm heads. This will cover the dish to hub and the dish to rim.
Brian
/ TIRE BOLT SIZE
OK
hopefully those are the ones that my tractor has.
thank you again.
Bradco 8611X Backhoe Attachment (A65579)
Bradco 8611X...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
1980 Fontaine Flatbed Trailer (A65563)
1980 Fontaine...
master diesel generator (A64553)
master diesel...
2007 Toro Z-Master Zero Turn Commercial Mower (A64553)
2007 Toro Z-Master...
2014 Ford F-250 Utility/Service Truck, VIN # 1FDBF2A67EEA87424 (A65563)
2014 Ford F-250...
