Ballast Tire ballast types
/ Tire ballast types #11
Has anyone ever tried a dry material like sand or even lead shot? It would be hard to get inside but seems like it would work well.
I'm sure someone has tried it.
Never did but going to bet that it will pack on one side more than the other and make for irregular tractor motion. If you had steel marbles, maybe they'd work, but it's have to be a tubeless tire and then it's still be a trick getting at least half the tire filled and then back on the rim. Still think there would be a time delay causing irregular movement.
Neatest thing I heard of was ww fluid. At about a buck a gallon not too bad full strength.
Here in N. TX. the local sales and service, any kind of tire, with farm, fleet and road service, 5th generation family, put 6 gallons of cheap ethyl-gly in a 55 gallon drum and filled her with water. That's went into each rear on my 6530. Long way from what you put in your radiator but he said that as long as you don't have ice chunks to slit your tube you are good to go. Said slush is ok. Well if he didn't know I guess no one would. So 6 gal at the $9-10 I paid him works out to about the same as full strength ww fluid and a lot of that is advertised down to 0F which surely would be lower than what I have. Also you don't have the (potential) corrosion problem like with CC. Back when I changed tires on my JD 4020, He pulled out 2ea 55 gallon drums of CC and water. I wanted them dry so I had no place to put it. So I put it in my 3000. Been lucky I guess. No visible problems, course, I haven't had any leaks nor flats either. I guess one of these days I ought to put in a couple of new valve stems.
On sloshing, I have noticed a slight amount immediately after abrupt stops. But generally, don't even know they're loaded.
2019 KUBOTA SVL75-2 SKID STEER (A62129)
2019 KUBOTA...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2007 International Derrick Digger Truck (A60352)
2007 International...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2000 TEREX 60TON T560 REAR WHEEL DRIVE CRANE TRUCK (A59906)
2000 TEREX 60TON...
2012 Range Rover SUV (A59231)
2012 Range Rover...
