Tips/ Tricks to remove broken wood fence posts
   / Tips/ Tricks to remove broken wood fence posts #11
One of the bigger Brush Grubbers should do it: BrushGrubber | Brush Grubber Products
Works on small trees:
   / Tips/ Tricks to remove broken wood fence posts #12
I "re-installed" the fence around my 80 acres when we moved on the property. 1320 x 2640. 745 T-145 posts - four strands of EverSharp barbed wire. That was 40 years ago. I quit having nightmares about this thirty years ago. 165 or so posts are in solid basaltic lava. The last of the "L - shaped fence line supports" were converted to T-145 posts four years ago. The neighbor has a commercial jack hammer and would come over every spring - for five years. Thirty or so post - every spring.
If I close my eyes and listen very carefully - I can still hear the "ringing" of my homemade manual pounder. Driving in the posts.
The joy of building fence on basalt. No matter what you do, it's going to be hard work.
   / Tips/ Tricks to remove broken wood fence posts #13
Cordless impact driving long lag bolt with washer through chain into top of post. Use loader where you can, new fence post for leverage where you can't. Works good if base of post is solid. Extract lag bolt and move on to next post. If base of post is punky and won't hold lag bolt this method won't work of course.
   / Tips/ Tricks to remove broken wood fence posts #14
If you had access to a backhoe with a thumb that may make easy work of things. Or a grapple on a loader, perhaps. Neither will work well if the posts are rotten though.
   / Tips/ Tricks to remove broken wood fence posts #15
When they are busted off, the remaining wood is usually splintered enough that a lag screw won't get good purchase.
I have good luck with a spade. Dig down about 8" or more on 2 sides and pry it out with the spade.
If the new post goes into the old hole, tamp it really good with the large end of a tamping/digging bar.
Great suggestions everyone! Thanks for the input.
I think I'm going to try the lag bolt next time I'm at the property and see how it goes.
I'll keep you all "posted". 😅
   / Tips/ Tricks to remove broken wood fence posts #17
6 foot prybar, some 2x6 and 6x6 wood for leveraging off the ground.
A backhoe with thumb works too.
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
Case 830 Tractor (A50514)
Case 830 Tractor...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52128)
2020 New Holland...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2014 Kia Sedona Van (A50324)
2014 Kia Sedona...
2020 HINO 195 CAB AND CHASSIS (A51222)
2020 HINO 195 CAB...
