Tips, tricks or any info on new to me dk40se hydro
   / Tips, tricks or any info on new to me dk40se hydro #11
DO NOT use 4wheel drive on bare dry pavement.
Thanks for all the the info . Good things to know . Did some bush hog work the other day and I love this thing
   / Tips, tricks or any info on new to me dk40se hydro #13
Good to hear!
I've found recently that if I keep my ground speed slow, even in medium range, and adjust my RPM according to the terrain and type of stuff I'm cutting anywhere from 2000-PTO RPM of 2500 that I get good results when hoggin'
Thanks I was in medium at about 2200 rpms and seemed about right
   / Tips, tricks or any info on new to me dk40se hydro #15
If you are running a PTO powered implement then jack the RPM's up to the little triangle on the tachometer.
   / Tips, tricks or any info on new to me dk40se hydro #16
If you park it inside a barn, lift the hood and leave it up. Mice seem to really enjoy Kioti wiring insulation.
   / Tips, tricks or any info on new to me dk40se hydro #17
Exactly.
Can, but not necessary, unless one needs all the RPMs to do the cutting needed. Then of course use them.
   / Tips, tricks or any info on new to me dk40se hydro #18
Exactly.
   / Tips, tricks or any info on new to me dk40se hydro #19
If you cannot find the hood release keep looking it's just shoved up tight to the frame.
I thought that box was for an emergency pint, tools in the cab.
Next ?? I lost a pin that is in the adj stabilizer it has a coter pin on bottom and I believe a rubber washer on top maybe on bottom too . Each stabilizer has 2 pin one in on a chain I believe I did not loose the one with the chain . Where is best place to look for these if need to I can take a pic of it ( prob be upside down) I went to a couple hard ware stores and found something to work til I can get a few of the real ones . Was hoping to stay away from dealer , prob be paying triple
UNUSED 1RANCH 1RGPM GROUND PROTECTION MATS (A57193)
UNUSED 1RANCH...
Cushman Electric Cart (A55851)
Cushman Electric...
LINCOLN ELECTRIC POWER WAVE 455M WELDER (A57192)
LINCOLN ELECTRIC...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2018 JOHN DEERE 26G EXCAVATOR (A52707)
2018 JOHN DEERE...
UNUSED SDLANCH SDLWC WOOD CHIPPER (A57193)
UNUSED SDLANCH...
