Tips, tricks or any info on new to me dk40se hydro
   / Tips, tricks or any info on new to me dk40se hydro #11
DO NOT use 4wheel drive on bare dry pavement.
Thanks for all the the info . Good things to know . Did some bush hog work the other day and I love this thing
   / Tips, tricks or any info on new to me dk40se hydro #13
Good to hear!
I've found recently that if I keep my ground speed slow, even in medium range, and adjust my RPM according to the terrain and type of stuff I'm cutting anywhere from 2000-PTO RPM of 2500 that I get good results when hoggin'
Thanks I was in medium at about 2200 rpms and seemed about right
   / Tips, tricks or any info on new to me dk40se hydro #15
If you are running a PTO powered implement then jack the RPM's up to the little triangle on the tachometer.
   / Tips, tricks or any info on new to me dk40se hydro #16
If you park it inside a barn, lift the hood and leave it up. Mice seem to really enjoy Kioti wiring insulation.
   / Tips, tricks or any info on new to me dk40se hydro #17
Exactly.
Can, but not necessary, unless one needs all the RPMs to do the cutting needed. Then of course use them.
   / Tips, tricks or any info on new to me dk40se hydro #18
Exactly.
   / Tips, tricks or any info on new to me dk40se hydro #19
If you cannot find the hood release keep looking it's just shoved up tight to the frame.
I thought that box was for an emergency pint, tools in the cab.
Next ?? I lost a pin that is in the adj stabilizer it has a coter pin on bottom and I believe a rubber washer on top maybe on bottom too . Each stabilizer has 2 pin one in on a chain I believe I did not loose the one with the chain . Where is best place to look for these if need to I can take a pic of it ( prob be upside down) I went to a couple hard ware stores and found something to work til I can get a few of the real ones . Was hoping to stay away from dealer , prob be paying triple
2010 VOLVO VN-VNL T/A ROAD TRACTOR (A57192)
2010 VOLVO VN-VNL...
UNUSED FUTURE FT-ZP210 20' X 30' ALLSTEEL GARAGE (A57193)
UNUSED FUTURE...
John Deere 3pt 9' Rotary Rake (A56469)
John Deere 3pt 9'...
2019 Harley Davidson Electraglide (A55973)
2019 Harley...
24ft T/A Flatbed Equipment Trailer (A55788)
24ft T/A Flatbed...
2016 CATERPILLAR 930M WHEEL LOADER (A52707)
2016 CATERPILLAR...
