Tips on loading dead tractor
   / Tips on loading dead tractor #1
JC2398
2019 Kioti NX55
My tractor won’t start and I may need to get it to the dealer next week.
Fortunately it’s in a gravel parking area behind my barn. I could probably get a trailer backed up pretty close to it, and will probably need to winch it onto a trailer.
My main concern is that the front bucket is on the ground. I’ve never dealt with that situation in loading vehicles.
Any good ideas on how to deal with that?
   / Tips on loading dead tractor #2
How much will the dealer charge to send a rollback?
   / Tips on loading dead tractor #3
Is the engine turning over? Just not catching. Or is nothing happening when key is turned over
   / Tips on loading dead tractor #4
You know it's gonna be a hassle, plus you'll have to get it off the trailer. A roll back even with the added expense would be the way to go.
As far as the loader, I've never delt with that, but I suspect you could put it in float, jack it up, take it out of float. It should stay up for a little while. Or you could fabricate some hydraulic cylinder locks and block the cylinders.
Not sure…It was about $100 a few years ago, but that was a guy coming out with a tilt bed trailer.
Depending on how much hassle it might be to deal with the front bucket issue, I may look at getting a tow truck company with a true rollback.
Not turning over at all. I think it’s something with some of the safety startup sensors. The dashboard lights up and shows an error code nothing happens when I turn to “start” position.
   / Tips on loading dead tractor #7
Work the winch cable under the bucket, then attach to the tractor, tie the loader lever back as if to raise the loader, as the cable tightens to pull the tractor, it will also raise the bucket enough to load.
   / Tips on loading dead tractor #8
I would just run the winch cable under the bucket and then attach to the tractor frame as high as possible. As you start to pull the cable will want to go straight which will put up pressure on the loader bucket, open the loader valve, when it gets as high as possible release the valve and let your loader stay there.
You may have to hold your brakes on the tractor to get enough lift on the cable.
Make sure to lock your brakes together before doing anything, wheel brakes are not good on top of a trailer.
g
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
Werner 14ft Fiberglass Extension Ladder (A57454)
Werner 14ft...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
KUBOTA LA525 TRACTOR (A59823)
KUBOTA LA525...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
