tips for smoothing trench
/ tips for smoothing trench
I think you guys are right that I need some more material. Was hoping to get away without the extra work.
wish I had a tiller, only a landscape rake an 6' box blade.
thanks for the ideas guys (y)
/ tips for smoothing trench #12
Agree there's more material needed. We've done a lot of trench work and backfilling is really simple. Backfilling without settling afterward is not.
There was one project with thousands of feet of ductbank was installed under paved areas. After a few years I had occasion to go back and see that there was no evidence of settling of the asphalt patches. In that case we discarded all the excavated materials and used (very well tamped) what we call "2A Modified". May go by a different name elsewhere. It's anything that passes through a 3/4" screen at the crusher, and has lots of fines.
Backfill material in dirt work (not in paved areas) was usually whatever came out of the trench. Again, it had to be well tamped. This was done with a jumping jack tamper or a walk-behind trench tamper. Running equipment such as a backhoe over backfill as a tamping method doesn't work well.
/ tips for smoothing trench #13
I also say a tiller would help a lot. Can you rent a small tiller?
/ tips for smoothing trench #14
Could you lower the box blade teeth and use it to loosen up and move some extra material? Ken Sweet
hh
/ tips for smoothing trench #15
I agree, I worked in fiberoptic and we installed the conduit by trenching. If we were going for a nice finish on someones lawn then it was a hand rake and then a hand leave rake to get all the dirt out of the grass. We would tamp but still have to haul the extra away. It would settle of course over time. The quick and dirty way is just to bring more dirt or if you don't care for the finish grade it in somehow.
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
2017 Case CX145D (A60462)
2017 Case CX145D...
2014 JOHN DEERE 50G EXCAVATOR (A62129)
2014 JOHN DEERE...
2014 JCB 930 (A53317)
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2020 Deere 50G (A53317)
2020 Deere 50G...
