Tipping a tractor
/ Tipping a tractor #41
Re: Where is the rollover point
Wen, it's more of a beeper than a horn, so I don't think it would be enough to make you bail out or something like that! /w3tcompact/icons/laugh.gif
I ordered the beeper model to put on for side-to-side tilt, and I'm going to take the existing non-beeper model and mount it for front-to-back slope.
Even with 4wd, I've gotten stuck in ditches so deep that it took pulling myself out with the front end loader to get unstuck.
Mark
/ Tipping a tractor #42
pdxman
Good to hear that you were not injured in the accident.
Front loaders are dangerous! Loader tractors should have a lower ground clearance,wider wheel base,approved ROPS, 3 point harness, and a brave operator.
I own 2 currently. that are only missing the 3 point, and on some job sites, the brave operator. Operating light,medium,or heavy equipment takes constant awarness, and alert to everything going on around, and under you.
Not uncommon to other posts, I have read elsewhere in this forum about certain types of transmissions being safer than other's. The safety can be so well pronounced that, a novice could become overwelmed with the saftey aspect and end up crippled, injured or even dead. (this does not omit the same for an experienced operator)
The manufactures are finally taking saftey seriously. regardless of the product. Our new boat has an option that shuts the engine down if the operator is thrown from the seat. Does that give the operator the security to drive the boat across the water in an unsafe manner? I should hope not.
As I always told my employee's. The only thing between you and the ground is, your butt and your brain.
sit on one, use the other.
Tell your in-law, its a piece of cake to lay one on it's side. hard to explain why. /w3tcompact/icons/wink.gif
Best of luck in the future.
Cowboy
sittin on his butt, and trying to figure out how to use the other. /w3tcompact/icons/smile.gif
/ Tipping a tractor #43
I would think a tiltmeter would have limited uses other than just fun. If the angle feels steep, it is. Unless you are a dozer operator with ice water for blood (those guys are something!) you'll probably be queasy before trouble hits, but looking at a tiltmeter isn't the whole thing, a hole, or a rock, sudden soft ground, especially if you are out of granny-low can send it over. I don't think most rollovers happen driving carefully on maximum-angle-before-rollover ground, I think a lot are near ditches etc. I put a track hoe over on it's side, wasn't near the edge but it slid on a tree root into the ditch. Metal tracks on wood are like tires on ice. I look at those rubber tracks I see on some small units differently now.
Speaking of rollovers I picked up an auger from a gentleman (who had an L35!) who had a dozer guy make a road down the side of a ravine for him. The dozer rolled down the ravine TWICE! See what I mean about dozer drivers! I would have thought once would have sent him home!
I mentioned this before, now with the L35 I wouldn't hazard this as I think the fops isn't strong enough, but on my Ford with the bomb repellent roof I always wanted to put a sling over it and use an excavator to slowly pull the tractor over to see it's tip point.
Of course one of you unfeeling gentlemen told me to put a good replica of my fat ass in the seat for accuracy! Couple 4 sacks of potatoes ought to do it? Any Idahoians?
Backhoes are of course worse and better on slopes, CG is moved up and back, but you can alter the CG by putting a big rock in the backhoe bucket and stretching the hoe out on the ground up hill. Same with loader bucket, nice load dragging the ground. But then again if it's that bad it sounds like a dozer with an angle blade should visit the hill first if you absolutely have to cross it sideways. Saw a couple of D3 sized units go for around 6-8K at the auction the other day.
/ Tipping a tractor #44
Bud, I agree; I wouldn't really want to drill holes in my new tractor hood or instrument panel. I have a steel canopy on my tractor with an angle iron frame, so that's where I mounted the tiltmeter (inclinometer), along with a work light and rear view mirror. And yep, I can believe that about having to buy dirt in the Georgetown area, but not within 20 miles of Navarro Mills Lake where I live./w3tcompact/icons/smile.gif
Bird
JOHN DEERE 5085E TRACTOR (A64277)
JOHN DEERE 5085E...
2018 Ford Escape SE SUV (A64557)
2018 Ford Escape...
Skid Steer Finish Mower (A65640)
Skid Steer Finish...
2000 Ford F-750 Debris Truck, VIN # 3FEXF75H8YMA01188 (A65563)
2000 Ford F-750...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
2022 EZ-GO ELITE...
