Tipped over Kubota BX24
   / Tipped over Kubota BX24 #1
96superjet
McDonald PA
Kubota BX24
The back end of my BX24 got away from me and ended up tipping the tractor over onto it's side.:eek: First the ROP did what it was supposed to do and no one was injured.:D It took approximated an hour before I was able to use my garage floor jack, tow strap and my truck to get the old girl back upright.
I have not yet attempted to start the tractor because I don't know what type of pre-maintenance I should be doing to the engine first. Could have oil entered the engine, air filter or other areas that it shouldn't have? Other than basic structural inspection, what type of engine maintance should I perform before attempting to start the engine?
   / Tipped over Kubota BX24 #2
I did the same thing with my JD about 16 yeas ago. Right tire fell into a hole while the left went over a leaf covered stump. It was like slow motion all the while my mind saying "this can't be happening" I was more concerned about the tractor than myself. Well, I jumped off, over she went, almost making a complete roll over and came to rest at about a 45 degree angle and not a good 45* but wheels up 45*. I looked at her and said " that can't be my beloved 750 lying on the ground like that" But it was and she stayed that way until I got a come along the next day and righted her. I just started her up and off we went to the barn and fixed her fender. She's been purring ever since.
   / Tipped over Kubota BX24 #3
96superjet said:
... ended up tipping the tractor over onto it's side... I have not yet attempted to start the tractor ...
96superjet, glad to hear that you are OK.
Begin by checking all the fluid levels (oils, coolant, battery...). If these are OK, then start the engine and check for unusal signals that something is wrong (lights flickering, noises, etc...). If that's OK, then proceed to activate and test various funtions (transmision, hydraulics, etc...). If they are OK, then I would assume that the tractor is fine.
More importantly, these mishaps can cause fatalities; you were fortunate not to be among them. It would be helpful if you were to explain how this mishap happened, so that others may learn to avoid similar situations in the future.
96superjet, thanks for your important post. LP.
   / Tipped over Kubota BX24 #4
That gave you a good chance to check the bottom for any leaks or such non normal things.
Wash off the battery/ the box and all areas near it and maybe also use some baking soda to neutralize anything that spilt if it did. :D :D
As I suspect is typical in most of these type situations, lack of good judgement was the main cause of the tip. I had been removing a tree stump, it was late (dark) and I was in a hurry to get done. I was finishing up by moving some of the excavated dirt and the back tire got too close to the stump hole that I had just excavated. The rest is kinda history.
If nothing else I guess this helps to place a stronger emphasis on safety (good judgement) in the future.
   / Tipped over Kubota BX24 #6
96superjet said:
... I guess this helps to place a stronger emphasis on safety (good judgement) in the future...
Thanks mate!
   / Tipped over Kubota BX24 #7
Glad to see you were not injured. I tipped over my b3030hsdc last summer as I mentioned with pics in a previous thread. I got my 2005 Dodge diesel and pulled it back up. Aside from a nice size bruise on my back side, and my pride, there was no damage. Not even a scratch. I started it up immediately and used it the rest of the day with no ill effects. I do have a resolution to have the tires loaded this year....
   / Tipped over Kubota BX24 #8
Glad to see you were not hurt in the flip. As the hours rack up on a piece of equipment you get a false sense of security in what it and you can do safe. Sometimes either because its late, your in a hurry, or just plain stupidity it will quickly bite you.
I have over 2,000 hours on my TLB and an early morning slip (coffee didn't kick in) coupled with a tad bit of attitude taught me a lesson last fall I will not forget soon.
I went from having one wheel over the edge to the resulting pictures because I thought I was good enough to get out.
NOT!
   / Tipped over Kubota BX24 #9
NOT!
That looks like a real heart breaker. How did you get it back out?
   / Tipped over Kubota BX24 #10
Super,
aside from structural ...
The worry with the engine is that oil will fill the cylinder (s) and when you crank it can hydrolock. That will break expensive stuff.
Thankfully, the oil will drain back. An hour is plenty, over night is 99% sure to be good. The only way to be 100% sure, is to pull the glow plugs out and crank that way. If a gyser shoots out, you saved yourself $3-6000. If nothing shoots out but air, you cost your self a few minutes of time.
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
2013 Mack GU813 Roll Off Truck, VIN # 1M2AX13C1DM019680 (A51572)
2013 Mack GU813...
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
NEW Ripper Shank (A53002)
NEW Ripper Shank...
378550 (A51573)
378550 (A51573)
2013 VERMEER VACTRON LP555 DT HYDROVAC TRAILER (A52472)
2013 VERMEER...
