TinyTach question??
   / TinyTach question?? #21
I agree, nice install. For an alternative to velcro, check out my posting on tiny tach. In it, I show a picture of mounting it lower on the rubber molding below the dash on a 1 1/2 inch piece of angle aluminum. This position has worked very well to allow quick viewing.
   / TinyTach question?? #22
Does the tiny tach require external power? If so what wire did you use?
Did you paint the transducer? If so did you use heat resistant paint?
Thanks.
Bob
   / TinyTach question?? #23
Hey Huskerfan,
I added a toggle just like you did but when I bought my toggle switch, I also bought a toggle switch cover. It's made of rubber and screws on the toggle switch. It was a buck or two for it. Thought it would help keep out the weather and dust. Just an FYI...
Jim
   / TinyTach question?? #24
Not a bad way to go, thanks for the tip!
   / TinyTach question?? #25
Best way is to tap into an unused area from the fuse block or you could go straight from the battery and add your own fuse holder.
   / TinyTach question?? #26
I just purchased a tiny tach for my BX22TLB but I am not sure of the hook up. Does or can anyone give this novice a set of pictures, instructions, etc on how to hook this thing up. I am really not sure about the battery hook up and the fuse block. The engine block ground is pretty straight forward.
Thanks for helping a newbie out (had my BX22 for 3 months and have loved every minute of it /w3tcompact/icons/love.gif Love that <font color=orange>Orange</font color=orange>)
200 Gallon Tank (A57148)
200 Gallon Tank...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 FREIGHTLINER PT126SLP TANDEM AXLE SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
LOT: (40) 14 Oz. Tubes of Red Lithium Complex NLGI #2 Grease (A59076)
LOT: (40) 14 Oz...
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
