TINY TRACTOR SERVICE
/ TINY TRACTOR SERVICE #1
TINYTRACTORSERVICE
BX24Look at my new way to get around;) This little BX fits just right in my 14'+3'over top uhaul box van. I love this set up room for Box Scraper up front and tiller in back under backhoe and can use it to pickupand set it down ramps go over the top of tiller.
/ TINY TRACTOR SERVICE #2
Looks Sweet... and you don't have to deal trailer towing and everything that goes with it.
/ TINY TRACTOR SERVICE #3
And the best part of all- out of sight and out of mind to the criminal element:)
/ TINY TRACTOR SERVICE #4
That is pretty trick, Be sure to mount some flush mount tie rings to to floor over the box frame. That will take the rear door right off if it gets moving around. Don't use the E track on the walls, It will destroy the cube
/ TINY TRACTOR SERVICE #5
What timber said. Tie that thing down before it rips it's way through the box....
/ TINY TRACTOR SERVICE #6
I would put some wood down for the out riggers to set on. They may vibrate and rub through the aluminum floor. Can you lower the back hoe's bucket for more stability.
Nice set up. Is your business up and running yet? Getting much work?
Cary:cool:
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
STORGE SPACE WITH MISC ITEMS (A68842)
STORGE SPACE WITH...
2005 CTS BELLY DUMP (A67714)
2005 CTS BELLY...
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
CAT 330BL Swing Drive (A68134)
CAT 330BL Swing...
