Tin Building for chicken coop
   / Tin Building for chicken coop #1
kcflhrc
Kansas
2013 John Deere 3032E
So I have an old tin building/lean to we have converted for a chicken coop. I'm putting in 3 2' x 2' sliding windows in for the enclosed part. Do you guys think that will be enough to keep it cool enough for them in the summer months? 1 south window, 1 north window and 1 east window. The east window opens to the lean to part.
   / Tin Building for chicken coop #2
How big is it? How much effort would it be to put in a ceiling and some insulation to keep from picking up heat from the roof? If you can do that you should stay relatively cool with the windows.
   / Tin Building for chicken coop #4
Looks like that should be open enough for good ventilation with the added windows
   / Tin Building for chicken coop #5
Are u worried about predators with no roof in pen? Also I think if u have some shade in outer pen for them they can go out there if it's to hot in side.
   / Tin Building for chicken coop #6
make area for them to roost as well.
I have a roost area built inside. The outside pen will be covered with 1" chicken wire. Any other suggestions?
   / Tin Building for chicken coop #8
will you be trying to keep bitties inside or not. if so.. 1" cw is small enough to let them wiggle thru, also predators like coon and possum can grab a chicken thru 1" wire, pull it to the edge and chew off flush as much as they can pull thru. if neither of those are a concern in your area, and no captive bitties.. not a problem.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2018 FREIGHTLINER...
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
New Holland L225 Skidloader (RIDE AND DRIVE) (A50774)
New Holland L225...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
