timing
   / timing #1
monkeyman
france
3 ton digger
hi.i got a mitsibushi k3h motor in my 3 ton digger.turned it off one day and would not start two days later.after a lot of trying i decided to rebuild.new rings ,honing,valves and a injector pump rebuild put her all together.still wont start,all the timing marks line up.anyone got an idea.fuel is getting thru after bleeding.
thanks
   / timing #2
You may not have enough cranking speed for ignition. Load test or swap the battery, if that's ok then check the current draw on the starter. Either will cause a failed start.
Chilly
   / timing
thanks chilly for that.theres no problem with the turn over speed.
i need to get in touch with anyone who has rebuilt one so therefore retimed it.
i have all the marks on the sprockets lined up.fuel at the injectors but not a hint of firing.its got to a timing issue.
mike
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
7033 (A51691)
7033 (A51691)
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
