timing marks Ford 941 high crop
/ timing marks Ford 941 high crop #1
wjkrostek
palmer ak
ford 3000 JD5310 Ford947 JD5525 Farmall 400
I can not find where to look for the timing marks so I can find 4deg before TDC. I found on the 600's none high crop there is a peep hole put I can not find a hole any where on mine.
/ timing marks Ford 941 high crop #2
If you can't find the marks through the insoection hole, take the starter out and then use that larger opening to look for the flywheel marks
I can not find where to look for the timing marks so I can find 4deg before TDC. I found on the 600's none high crop there is a peep hole put I can not find a hole any where on min e.
Thanks for your picture. it made me look harder. IT was there. Shame on me. thanks again
/ timing marks Ford 941 high crop #4
A person can never have too much help or tools!
