tilted deck one bald caster
   / tilted deck one bald caster #1
redhotpipe
south amherst ohio
cubcadet 3240
hello i have a 3240 with hydraulic lift. the deck goes up and down all the way in the rear. the problem is in the front. when you pick it up to go somewhere th right fron caster is still on the ground. i so far have checkd the lifting arms, they both go all up to hit frame so it is not a travle problem. ihave tried to adjust the front u bolt, in, out, more left, more right, nothing seems to help. any clues what i am doing wrong? any suggestions on what parts might be bad. oh ya it is 48 inch deck. thanks for any help
   / tilted deck one bald caster #2
Is castor adjusted all the way down?
no the casters are one hole from the top. the front right corner just wont come off the ground. left front is up about4 inches.
   / tilted deck one bald caster #4
Sounds like your right front hangar is either disconnected, missing or way out of adjustment.
Does the deck look that far off level from the front?
Curt
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
19008 (A56859)
19008 (A56859)
Club Car Electric Utility Cart (A55853)
Club Car Electric...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
Deere 335P (A53317)
Deere 335P (A53317)
