tilt trailers
/ tilt trailers
just got back was using a friends tilt trailer nice trailer only problem I see is its real steep for me to get up and into the tractor when its tilted
going to have to see if I can find a rollback anywhere near me
looks a lot friendlier to my leg and as most of the time I will be using it is winter (after all that can be half the year we had an inch of snow yesterday ) thanks for the input all
/ tilt trailers #33
I've been daydreaming about rollback trailers ever since I found the link to them.
I even talked to the local trailer guy about a roll back when I went in to get a new tongue jack for my newest trailer. He said that fewer places are building them nowadays. Apparently they were very popular before the turn of this century, but the demand has tapered off in the past decade. Anyone know why?
/ tilt trailers
I done some checking the last couple of days on these
found out the texas rollback company is no more
however they are still being made by sloans kwik load
Rollback Trailers Kwikload Trailer Roll Back Trailers Kwik Load Trailer
is the place I called and their nearest dealers that stock are all at least 750 miles from me and all want at least $4750. for them
however he does have a factory direct option starting at $3895.
I figure if I have to drive 750 miles to pick one up
I might as well drive 1040 course then there is the option of putting hydralic or cable actuated ramps on my existing old trailer
decisions decisions!
/ tilt trailers #36
going to have to give those guys a call I like that rollback will have to see the price
It looks good, but the rear end of the deck wouldnt be allowed in my country: it would need a steel underride protection of at least 4 inch high.. Even though most cars that rear end one of these, will bounce on top of the deck instead of jam themself stuck under..
I do wonder about the effect of the rollback system on the road behaviour though.. i guess it would allways have a bit of slop.. Does anyone have pictures of it ?
Oh, and another possible drawback of the rollback trailer: You need to pull the bed back over the axles, from a point where the center of gravity is behind it. Can a 2WD truck do that, or does it require 4wd ???
At my former employer, we had a German dealer that made trailers with individual hydraulic suspension: you could let these trailers kneel by releasing the hydraulic system. With the deck flat on the ground, the ramp angle is an absolute minimum.
Drawbacks are the high price, and that you still cant load anything with doors that you need to get out through, when driving a vehicle on them. Those trailers are popular for commercial cleaning companies, that need to transport low clearance floor sweeps and cleaners from one office building to the other.
/ tilt trailers
well for me the 2 or 4 wheel isnt a big concern as all I pull with are 4x4
however I have used a very large 24 ton rollback before with a single axle tractor to haul an excavator and we never had trouble rolling that back up.
A time or two with fresh snow on ice had to start the load moving then hit the trailer brake and lockem up to get it started but as soon as it starts moving up the load starts addding weight to the fifth wheel
/ tilt trailers #38
With a price of $4750, you can get a better trailer with electric tilt. Manual till will save another $1000. I paid $5300 for electric tilt, 24', 14K with several other options a few years ago. Electric/manual tilt will have a higher angle but are quick and easy to use. I have a '34 Ford street rod. The front bumper is 4-5" off the ground and I can drive it on my tilt bed.
I am not big fan of steel decks. They can become really slick with a little water or oil.
/ tilt trailers #39
But how about the mechanism ?? is it slop free, does it crunch when it sees a little sand, does it have any effect on the ride quality or durability ??
i mean,
There must be a reason for what Iplayfarmer said ??
/ tilt trailers #40
You can't beat a tilt trailer.
I've got a 20" that is the cat's meow.
No mo ramps is a real advantage.
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
CASE TV380 SKID STEER (A62129)
CASE TV380 SKID...
Attention (A57148)
Attention (A57148)
2019 Tiffin Zephyr Class A Motorhome (A59231)
2019 Tiffin Zephyr...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
2025 VR59 Hydraulic Vibratory Roller Skid Steer Attachment (A59228)
2025 VR59...
