Tilt Trailer Without Hydraulics
/ Tilt Trailer Without Hydraulics #1
Dan Hunter
Platinum Member
Enid, OK
2012 John Deere 3720 eHydro
I bought an Interstate 16 x 7 tilting trailer to haul my JD 3720 without exceeding my new truck lower towing rating. Picked it up and parked it a year ago. Haven't used it until....
I went to use it this weekend and found a problem. I have to believe the rear pin didn't have clips on both sides as the pin had fallen out and ground most of the mount eyes off even grinding into the cylinder and the hose elbow. For extra fun, when I backed it into the parking spot it hung up and bent the front mount.
This is annoying as I've literally never hauled anything on it; just took possession and parked it. I suppose I can get a replacement cylinder and pins with both clips and locally have the front mount repaired. How essential it the "snubber"?
/ Tilt Trailer Without Hydraulics #2
Been there, done that. Pin dropped on a dirt road, trailer pole vaulted a bit, busted lines, pretzled the rod. Mine is a power tilt though.
I'd imagine things are going to slam pretty hard without the dampener.
2012 Ford F-450 4x4 Altec AT200A 30ft Bucket Truck (A61573)
2012 Ford F-450...
2005 John Deere 6x5 Rotary Mower Tractor Attachment (A61572)
2005 John Deere...
Cat CB24B (A60462)
Cat CB24B (A60462)
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
Kubota KX121-3ST Mini Excavator (A61572)
Kubota KX121-3ST...
