Tiller tines won't turn
   / Tiller tines won't turn #1
ray2024
kubota mx5800
Countyline 6ft tiller about 5 years old, gets used about 4 hours per year.
Hooked up to tiller turned on pto. tiller tines turned for about 10 minutes in field then stopped turning. Usually the slip clutch and a rock are involved. Not this time, slip clutch works fine, output shaft from pto gear case to side case is turning. Can manually freewheel left rear,can't turn right rear manually and it barely turns with pto engaged left side not at all.
So since I was in a hurry to finish deer food plots didn't investigate further just parked it and unhooked. Looked at a new unit at TSC today hoping to see shear pins, no such thing obvious on new one.
yes its full of gear oil, and has never leaked
It is gear driven no belts or drive chain
Looking at parts diagram don't see anything that would be obvious issue externally so guessing it inside side gear box?
Don't want to (If you know what I mean)but Not a problem digging into it but would like to start in sorta right area on equipment.
If somebody out here has similar experiences and fix would appreciate hearing from you.
Thanks in advance!
   / Tiller tines won't turn #2
Sounds like a shear key on one of the gears or possibly the one where the cross shaft joins the gear box.
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
2422 (A60432)
2422 (A60432)
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2016 HAMM H7I VIO SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7I VIO...
43024 (A59228)
43024 (A59228)
1991 International 4900 Box Truck (A55315)
1991 International...
