Tiller Tiller - Tines on one side only?
   / Tiller - Tines on one side only? #1
jc7622
Edmond, Oklahoma
Montana 5740C
I really want a weed badger, but they are too much money for me. Last year I tilled under my grapes by tilting my 3pt tiller crooked (at an angle) tnd then shifting it as far to one side as I could. It worked OK, but was still not ideal.
Here is my idea: I'm thinking about removing the tines from all but one side so that I only have an 18" tilled are and then maybe having the attachment points moved over a little bit so that it sticks out from the tractor about a foot. This will allow me to till a narrow swath onder the vines.
Can anyone think of a reason that this might not work? Will tines on one side only cause any problems with the bearings or whatever else?
   / Tiller - Tines on one side only? #2
Run it long enough that way and the rotor will wear where it is unprotected by tined. Eventually, you won't be able to bolt tines to it.
   / Tiller - Tines on one side only? #3
Give it a try and see how it goes. :D You may be happily surprised.:D
Any problems with the drive shaft angle?
I have removed the outer row of tines on my tiller when the going was too hard for my little tractor. No adverse affects were noticed.
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2019 Kubota RTV-X1140 4x4 Diesel Utility Cart (A56857)
2019 Kubota...
Case 1083 20ft Corn Head (A55315)
Case 1083 20ft...
