Tiller Tiller - Tines on one side only?
   / Tiller - Tines on one side only? #1
jc7622
Edmond, Oklahoma
Montana 5740C
I really want a weed badger, but they are too much money for me. Last year I tilled under my grapes by tilting my 3pt tiller crooked (at an angle) tnd then shifting it as far to one side as I could. It worked OK, but was still not ideal.
Here is my idea: I'm thinking about removing the tines from all but one side so that I only have an 18" tilled are and then maybe having the attachment points moved over a little bit so that it sticks out from the tractor about a foot. This will allow me to till a narrow swath onder the vines.
Can anyone think of a reason that this might not work? Will tines on one side only cause any problems with the bearings or whatever else?
   / Tiller - Tines on one side only? #2
Run it long enough that way and the rotor will wear where it is unprotected by tined. Eventually, you won't be able to bolt tines to it.
   / Tiller - Tines on one side only? #3
Give it a try and see how it goes. :D You may be happily surprised.:D
Any problems with the drive shaft angle?
I have removed the outer row of tines on my tiller when the going was too hard for my little tractor. No adverse affects were noticed.
2008 41ft KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A55853)
2008 41ft KZ...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A55853)
2009 Skeeter SL190...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
Kawasaki Mule 2510 4X4 Utility Vehicle (A55853)
Kawasaki Mule 2510...
