tiller sub compact
/ tiller sub compact #1
Maestro71
Ohio
Kubota bx2660 loader mmm back blade woods rotary cutter
will a tractor supply 48" tiller be a problem on a bx if it isnt the model designed for subcompact?
thank you
/ tiller sub compact #5
They both worked on my bx25 but are taller an 3pt hitch pins are higher then the subcompact models so it won't lift up as high for clearance. A real pain loading the machine onto a trailer with steep ramps. An also coming off or going up a steep hill Tiller always bottoms out on the ground. I had to switch to the sub compact country line 48" instead of the regular model cause of ground clearance.
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
