Tiller size ?
/ Tiller size ? #1
HK45
Bethlehem, Pa
Kioti nx6010 loader backhoe
I have a rotary tiller question? My new machine is 6.89 feet wide. Will a 7 footer be okay or should I go up to 8 footer. Im not sure if tillers are true to size or overall bigger then the size stated. Thanks
/ Tiller size ? #2
Now my head will be spinning all day.
6.89 feet! Sure it's not 6.89137 feet.
I'm sorry...but what is it? PTO tiller? PTO hp, etc. Sounds like 7 ft. Is right. Maybe tiller is 6.97ft.?
/ Tiller size ?
Pto tiller, 61hp pto.
/ Tiller size ? #4
Check with the Tiller manufacture for PTO HP requirements and factor in the soil type your going to be dealing with then go with biggest tiller with margin so as not to run out of HP.
Suspect 8' should work well with 61 PTO
/ Tiller size ? #5
Have you thought about buying a used Whirlwind Levee Plow to do your tilling? You can build raised beds in one pass and incorporate lime and gypsum deep and break the hardpan as well in one pass.
/ Tiller size ?
I'll have to check that out. I never heard of it before.
/ Tiller size ? #7
Rural king has a 7 ft country way tiller for i beleive 1700 bucks , the king cutter is 2500.
Quick Attach Backing Plate (A65579)
Quick Attach...
2015 MACK GRANITE (A65643)
2015 MACK GRANITE...
GREAT PLAINS 1006NT - 1575 NO-TILL GRAIN DRILL (A64277)
GREAT PLAINS...
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
2017 Ford Escape SUV (A64557)
2017 Ford Escape...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
