Tiller size ?
/ Tiller size ? #1
HK45
Bethlehem, Pa
Kioti nx6010 loader backhoe
I have a rotary tiller question? My new machine is 6.89 feet wide. Will a 7 footer be okay or should I go up to 8 footer. Im not sure if tillers are true to size or overall bigger then the size stated. Thanks
/ Tiller size ? #2
Now my head will be spinning all day.
6.89 feet! Sure it's not 6.89137 feet.
I'm sorry...but what is it? PTO tiller? PTO hp, etc. Sounds like 7 ft. Is right. Maybe tiller is 6.97ft.?
/ Tiller size ?
Pto tiller, 61hp pto.
/ Tiller size ? #4
Check with the Tiller manufacture for PTO HP requirements and factor in the soil type your going to be dealing with then go with biggest tiller with margin so as not to run out of HP.
Suspect 8' should work well with 61 PTO
/ Tiller size ? #5
Have you thought about buying a used Whirlwind Levee Plow to do your tilling? You can build raised beds in one pass and incorporate lime and gypsum deep and break the hardpan as well in one pass.
/ Tiller size ?
I'll have to check that out. I never heard of it before.
/ Tiller size ? #7
Rural king has a 7 ft country way tiller for i beleive 1700 bucks , the king cutter is 2500.
Aluminum Deer (A65583)
(2) Vermeer 9255 Tracks (A66408)
(2) Vermeer 9255...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
Husqvarna YTH24K48 Riding Lawn Mower (A65579)
Husqvarna YTH24K48...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
2005 20 Ft. Grady-White Boat with 25 Ft. Float-On T/A Boat Trailer (A64557)
2005 20 Ft...
