Tiller tiller size
/ tiller size #1
tommyc
Arkansas
JD 4210
Have JD 28 hp 4210 E-hydro (pto 22hp)--I have been trying to decide between First Choice RTO4 60 inch and RTO4 48 inch (Gear box is permanently offset). The 60 inch would cover my tracks but I am concerned that the 22hp is not enough. The 60 inch is $100 more than the 48 inch. I can live with the 48" since the offset will cover one wheel track but I would prefer the 60" for $100 more. Has anyone tried removing one set of tines to compensate for low power and tough soil? I noticed Frontier tillers sold by JD have only 4 tines per plate compared to 6 on First Choice. For a 60 inch tiller would the 4 tine be less of a load on the pto than a 6 tine? Would it require less horsepower? The Frontier is about $600 more. Thanks in advance for any information!!!!!
/ tiller size #2
I have a NH1630 which has a engine hp of 27.3, pto hp of 24?
Handles a 58 inch King Kutter tiller with no problem. When the soil is quite wet, I just slow down to range 1 and go.
/ tiller size #3
My last rig was also about 23HP at the PTO and I used a 60" tiller. The only time I had to slow down was with real wet soil conditions or if I tried to go too deep on the first pass. If you use your head you should be OK on the larger tiller.
/ tiller size #4
I've removed half the tines from my rotatiller. Works well but may take more passes. One can also overlap passes which may or may not help.
The type and condition of soil has a lot to do with the required PTO HP.
What works in nice loam may not in some good old clay. Breaking sod will also be more difficult.
The slower you travell the deeper you'll dig also requireing more power.
Egon
/ tiller size #5
My JD 850 (26 HP, 22 PTO HP) runs a 60" King Kutter 6 tine tiller OK.
/ tiller size #6
Tommy, I run a B7500 (16 pto hp) with a Landpride RTA 1550 tiller (48") just fine in Northwest Clay. The tiller has six sets of tines. On a horse power/tine basis you should be able to support a tiller with 8 sets of similar tines. The individual tines are 4" horizontal and 3" wide, with a 1" lift, on both left and right of a set.
/ tiller size #7
<font color="blue"> I noticed Frontier tillers sold by JD have only 4 tines per plate compared to 6 on First Choice. For a 60 inch tiller would the 4 tine be less of a load on the pto than a 6 tine? </font>
Just the opposite is true--6 tines will pull easier than 4 per rotor and will not transfer as much vibration to the tiller, tractor and its operator--Ken Sweet
Sweet Farm Equipment LLC *Over 1000 pieces of new and refurbished Equipment*
/ tiller size #8
[ -6 tines will pull easier than 4 per rotor ]
I've found just the opposite appears for my situation.
Egon
/ tiller size #9
Sweet is correct on this. A 6 tine per flange actually takes less HP than the 4 tine per flange. The 6 TPF tillers take smaller bites of soil and have less vibration because the scroll of the 6 TPF eats away at the soil where the 4 TPF chops away at the soil.
/ tiller size #10
I'd say the "easier" / "harder" question can only be answered in light of the type of soil you're dealing with. In my clay, the 6 tines get gummed up a whole lot quicker...and definately puts more strain on my tractor than when I remove tines.
That said, I have been relatively pleased running my 60" tiller with about 17 PTO HP. Since you have a hydro, I would think you could handle just about anything with the super speed control...my slowest is 1st gear. Sometimes that's not slow enough, so I end up having to take shallow cuts and run over it more times.
There are times I do wish I had gone with the 48" tiller: when I'm too impatient to wait for the clay to dry out enough (probably every Spring /forums/images/graemlins/wink.gif )
Sam
/ tiller size #11
HP is not much to a 200 HP auto engine but going from 17 to 22 HP is a 30% increase in power and that is noticeable. The JD 4210 could even accommodate a 66" CCM Gear Drive tiller. I do not think a JD 4210 would have any trouble pulling a FC- RT04-60 tiller.
/ tiller size #12
Egon, I think what Ken is talking about is a six tine 60" tiller will pull easier than a 4 tine 60 " tiller. In your case you removed tines and either shortened the width or removed alternate tines.
/ tiller size #13
It's a Farm king rotatiller with five four tang flanges. I removed two tines from each flange. For my conditions this works very well as I can now get the slip clutch to work. With a full tine set there wasn't enough power to get the clutch set properly. I could only get it adjusted to constant slip or a real fast engine stall. This was after many tries.
Now if more tines turn easier so be it but my experience was quite different.
Picture of tilling attached.
Egon
/ tiller size #14
Hey guys I asked this question over on the Mitsi/Satoh section, but haven't gotten any answers, and it fits so nicely in this thread. I've got a S650G, book data is 25HP/22HP PTO. (Seems like an awefully efficient transfer of power to me) Anyway I'm looking to get a tiller for it and am not sure what the size would work best. I've looked at a couple 56" units but am concerned that I don't have enough HP to handle it. Oh yeah, the 650G is a gas engine tractor. Thanks for any help.
/ tiller size #15
Egon, hard to argue with that. Someone smarter than me will have to figure this out. Perhaps tilling the tall stuff has something to do with it. /forums/images/graemlins/confused.gif
/ tiller size #16
Smarter than me to. The tall stuff was rye being tilled under. Week later there was a real nice catch for the fall deer feed.
Egon
/ tiller size #17
<font color="blue"> Week later there was a real nice catch for the fall deer feed.
</font>
Egon, to me this means you have been successful fishing but I know deer don't eat fish so that can't be it. Did you plant something else or did the rye re-seed??
/ tiller size
Sorry about the long delay in a reply. Changed over from dial-up to dsl and it didn't go smoothly. SBC-yahoo sent me a bad ethernet card. They are sending another and I am now hooked up with USB. DSL sure beats dial-up. Thanks for all the advice on tiller size. I think I will go with the 60 inch rather than the offset 48". I still have a few worries about it but I can always remove the tines off one flange. I have really enjoyed reading the discussions here each day and am amazed at what can be learned.
(16) Kinze 3000 Insecticide Boxes (A65640)
(16) Kinze 3000...
2014 FREIGHTLINER CASCADIA (A65643)
2014 FREIGHTLINER...
2003 International 4300 Bucket Truck (A62613)
2003 International...
2026 Kearney 102"x36' Gooseneck Trailer (A64126)
2026 Kearney...
2006 Honda Accord Sedan (A64557)
2006 Honda Accord...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
