Tiller shear bolt.
/ Tiller shear bolt. #1
rich1010220
Akron Ohio
YM1610D Yanmar
While tilling with my 1610D and 1200 tiller the times quit turning. /forums/images/graemlins/confused.gif I found the shear bolt on the tine shaft broke. A 5/16 bolt fits perfectly and I'm thinking of using a grade 3. Is this the proper thing to do or do I need to get an origional shear pin.
Rich
/ Tiller shear bolt. #2
Rich, can't help you but can you tell me where the bolt goes or is ? I can find mine at all. Do you have a yanmar tiller? thaks, bw
Brett,
The bolt is on the outout shaft of the chain case right next to where the tines are. I took the bolt to work and tested it on the Rockwell, a grade 3 bolt was almost the same hardness. I put it in and tilled some more tonight. I do like things proper so that is why I'm looking for the correct pin. It is a RS1200 Yanmar tiller.
Rich
/ Tiller shear bolt. #4
This post makes me think. I need to check my shear pin, and maybe everyone should. I was tilling last weekend when a big rock got jammed in the tines and killed the motor. That shear pin should have sheared, so I'm thinking someone replaced it with something stronger not realizing what it is actually for. Luckily no damage was done but you never know next time.
Mike
/ Tiller shear bolt. #5
Most shear pins on tillers and other PTO equipment are grade two, the bolts with no hash marks on the top. the idea is to destroy the bolt and not equipment. I would not put a #3 in. Are you sure its 5/16, most are 1/2"? Have you thought about putting in a clutch, saves replacing shear pins and is easier on the equipment
/ Tiller shear bolt. #6
I am using a yanmar rs 1300 tiller behind my YM2000 tractor. I am having the same problem with bolt shearing as rich101...... Anyway, I have installed a spring clutch on my pto, and I am still having to replace grade 8 bolts in the tine shaft. I am getting so frustrated with this and dont know why this is happening. I would think the clutch would eliminate the bolt breakage problem. I tried grade 5 bolts and they shear like nothing. When I got the tiller I had to do some reworking. It looked as though the splined shaft had been welded at one time. Wondering should I do this again being I do have the spring clutch. IMG00720-20120213-1507.jpg
/ Tiller shear bolt. #7
sounds like the slip clutch isn't working properly. JMO ..I think the clutch should slip B-4 breaking a grade 8 bolt
/ Tiller shear bolt. #9
I just backed all the bolts off and spun the tines. Now starting to re adjust the bolts. Maybe factory paint was holding. Right now it is tighter about 3 threads from the end without slipping.
/ Tiller shear bolt. #10
To me,IMHO, YOU MIGHT LOOK INTO THE BEARINGS.. That is a lot of torque to be shearing high grade bolts??
/ Tiller shear bolt. #11
I was taught that with slip clutches, you want to take the tension out of them, lock the tiller, and make the clutch smoke, to burn off the varnish if new, and then if older, it will polish the rust of the plates. Won't hurt anything, and then tighten the bolts until the attachment works, but the clutch will still turn under a dangerous load.
/ Tiller shear bolt. #12
If a 5/16 bolt is close then most likely it was originally a M8 bolt. Do you still have the original bolt's head? It may still have the markings to tell it's grade.
2000 FREIGHTLINER FL80 WATER TRUCK (A67714)
2000 FREIGHTLINER...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
2011 BRENNER TANK 200BBL CRUDE TANKER (A67714)
2011 BRENNER TANK...
2020 CATERPILLAR 316 FL EXCAVATOR (A65056)
2020 CATERPILLAR...
2009 FORD E250 CARGO VAN (A66091)
2009 FORD E250...
