Tiller Recomendations for JD790
   / Tiller Recomendations for JD790 #1
GONO2
South Central Virginia - GONO2 = Go # 2
JD 790
Can someone help me with tiller recommendations for my 790? I see where some are using 5' wide. Do you wish you had gone 4' wide or is 5' working OK? The only place I have locally will be County Line at TSCO, Frontier at JD, or Land Pride (think it's priced too high though). This will mainly be used for food plots, tilling small areas (less then 1/4 acre).
Thanks!
   / Tiller Recomendations for JD790 #2
I'd go with the 5', and if running short on hp then go slower and/or less depth. Or make a second or third pass. I assume the 4' won't cover your tire tracks. My 5' on my 4300 works just fine. Maybe the hydro tranny helps to adjust speed too.
   / Tiller Recomendations for JD790 #3
You shouldn't have any problem running a 5' with 26 pto hp. I run a 4' with 18 hp without any problem.
   / Tiller Recomendations for JD790 #4
790 will run a 5 footer fine.
   / Tiller Recomendations for JD790 #5
I run a 5 foot king kutter with 19.5 pto hp. I have had no problems with power however my tractor is hydrostat so adjusting speed is very easy. I can till much faster with this then I can with a walk behind rear tiller and have not wanted for more horsepower always was able to go at whatever speed I chose in my soil.
   / Tiller Recomendations for JD790 #6
I owned a 790 and used a KK 5 footer behind it. Perfect size for that tractor IMO.
   / Tiller Recomendations for JD790 #7
I have a KK 5' tiller for my 790 and as foggy1111 stated and I agree it is the perfect size for it. I have never wished I had gone smaller either. Covers tracks perfectly and the 790 has plenty of power for it.
   / Tiller Recomendations for JD790 #8
Ive run a 5' KK tiller on my 2520 since 2006 and no problems..
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2008 Doosan Mega250-V Articulated Wheel Loader (A52377)
2008 Doosan...
PALLET OF EXTENSION CORDS AND AIR HOSES (A53843)
PALLET OF...
2239 (A51244)
2239 (A51244)
48 PIECE HEAVYEQUIPMENT KEY SETS (A53843)
48 PIECE...
