Tiller Tiller Mod
/ Tiller Mod #21
I was sure thinking of your invention yesterday as I was using a hoe to pull up my beds after tilling with my Woods PTO Tiller.
By the fall, I should have something made up to solve that labor problem!
Nomad, that looks like a good idea to add to the tiller, very similar to the poster's but with that middle buster type spade, instead of the half shovels on his, the dirt would be pushed out more to the sides instead of the neat beds that he made right?
Or would the adjustment make this a non-issue?
John
/ Tiller Mod
The receivers are welded to the tiller about 1 1/2" down from the top of the tiller frame to the bottom of the receiver with a plate added to cover the back of the receiver and to add more weld area. My tractor has no trouble pulling the load, this is a finishing tool. I disk and chisel plow the garden first with my other tractor then run the tiller over it with the bedding tool removed until I get the seed bed I want then attach the toolbar and run off the rows.
/ Tiller Mod #23
Now you only need to add one more tine with a chisel on it to dig the furrow in the top of the bed. You could just make it a longer tine that could run between two of the S tines at the top of bed. Should really be easy to attach it to the tool bar.
John
/ Tiller Mod #25
Nomad care to share any more info on that ridger, combining these two designs would appear to be perfect.
Wall do you happen to have part numbers since you ordered them?
/ Tiller Mod
I am proud of my country and I fly the flag to honor the brave men and women who fought for our freedom and continue to fight to this day so that I can buy what ever tractor I want! Oh yeah and I am proud of my tractor too it’s a nice machine……................
/ Tiller Mod #27
Wall,
It took a bit to figure it out, but now that I see it, if I had to stand in one corner or the other, I guess I would be in yours... /forums/images/graemlins/tongue.gif
Not sure why we should need corners though... /forums/images/graemlins/frown.gif
/ Tiller Mod #29
Guys,
FYI my tiller has a removable V cut into the the back gate. It leaves a nice big raised row as you till along. If you want the ground all flat, the V fits back in and is bolted down. It seems to me that this could be done with any tiller as long as you are willing to cut the V out and then add an a flange on the inside that you drill thru so you can bolt it back if you wish. Just a thought. My tiller is a gray market Yanmar.
/ Tiller Mod #30
</font><font color="blue" class="small">( FYI my tiller has a removable V cut into the the back gate. )</font>
That sounds like an easy modification. I wouldn't think you'd get a very high hill though. I decided to buy a leinbach two disc bedder. A lot more work, but it does the job, and I'm getting nice wide, high hills from it. Once I learned how to set it that is!
John
/ Tiller Mod
"S" tine shank JD part # N185521 $22.25
"Clamp" JD part # N185522 $4.05
This shank and clamp will fit 3x3x1/4 tube steel
You can look these up, see the parts drawings and order online @ JD parts just register it is free. It is the same drawings that the dealer has.
/ Tiller Mod #33
</font><font color="blue" class="small">( "S" tine shank JD part # N185521 $22.25
You can look these up, see the parts drawings and order online @ JD parts just register it is free. It is the same drawings that the dealer has.)</font>
Hmm. Significantly cheaper at Agri-Supply.
S-tine #27804 32"x10" @ $5.70 each
heavy duty S-tine 42"x12" @ $14.72 each
3x3 clamp #29757 @ $1.99 each
Bedding sweeps ranging from 10" to 24" prices are $3.71 to $13.77 each
Agri-Supply catalog - see page 20
/ Tiller Mod #34
This project certainly got my interest. I printed out the Agri-Supply catalog on page 20 and was wondering how I should go about determining which bedding sweeps to order. Any suggestions?
/ Tiller Mod #35
I have no idea. I am not a farmer or gardener, yet. However, I did purchase one s-tine and one clamp that I will be using to prototype up something for myself later this spring.
/ Tiller Mod #37
I'm gona have to build one, has to save a ton of time. What if one was to fix the shovels to a rotating shaft at the rear and add a hyd cyl on a crank arm. One end of the cyl would attach to the back side of the top link, the other to the crank arm keyed to a shaft with the shovels fixed to the rotating shaft. Think you would be able to raise and lower the shovels from a remote on the tractor??? You could do your rough passes with the tiller first and tilt and the shovel raised. Tilt the shovels down when the soil is ready and cut your rows. More trouble than it's worth???
Chris
/ Tiller Mod #38
Wall, I followed your lead and made up a similar setup.
/ Tiller Mod #39
another view
/ Tiller Mod #40
the results
CHEVY 4X4 DUALLY TRUCK BED (A63569)
CHEVY 4X4 DUALLY...
2001 International 4000 DT 466E (A60462)
2001 International...
SnowEx Rotary Broom SS4000 (A64047)
SnowEx Rotary...
Cat 262D Wheeled Skid Steer (A64047)
Cat 262D Wheeled...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2001 Eager Beaver 50 Ton Hydraulic Detach Lowboy Trailer (A64047)
2001 Eager Beaver...
