tiller and MMM maint
/ tiller and MMM maint #1
v8only
Mb
1988 John Deere 755
So with summer just around the corner i want to do some first time maintenance on my tiller and MMM on the 755. Other than a gear old change is there anything i should do?
What fluids do i use the the tiller and mmm and what is the easiest way to drain and add as there are 3 plugs on each gear box.
Thanks
/ tiller and MMM maint #2
Thanks
Belts, u-joint zerks, and gear box oil (including the chain case). That's about it. Your owner's manual should provide the specifications for the exact oil specs. In general, I've used a high quality 75w-90w gear oil.
I bought a suction plunger at NAPA to pull out the old oil. It takes some time...
AKfish
i checked my tractor owners manual it says nothing about fluid types or how to drain them on the mmm or the tiller.
So using 75w90 in both gear boxes?
/ tiller and MMM maint #4
On the gearbox that the pto shaft connects to, there should be a nut that should be able to drain it and for the side gear case as well. Grease your Tiller about every 8-10 hours. Not too much grease that it gets all over the place. 1-2 Pumps should be good.
/ tiller and MMM maint #5
My new tiller has a drain plug on both the chain case (gear drive actually) and the gear box. My older tiller did not (gear box, no - chain case - yes) hopefully, your tiller will have a drain plug (as well, the MMM) if not -- you'll have to suction the old oil out.
I assumed that with an older model (755) tractor that your tiller would be similar to my older model JD 660 - no drain plug. That said, you know what they say about assume...
75w-90w is a fairly standard gear box lube.
AKfish
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A65563)
2008 Hino 268...
Hayrack Wagon (A66408)
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2000 International 4900 Tandem Truck (A66285)
2000 International...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
