Tiller Tiller Advice for SCUT
   / Tiller Advice for SCUT #1
gdBX
Finger Lakes
Kubota BX-24, JD 235GT
Looking for advice on tiller for BX-24, for gardening in heavy NY clay and lawn refurbishing. Plan to break garden up with subsoiler first ;).
Manual suggests maximum tiller cutting width of 42", and a maximum tiller weight of 375 lbs. the PTO is rated at 17hp. Seem's from the great posts that many are running larger ones, Dealer suggests a Woods Model GTC40 but it does not cover the 44.5 inch wheel base, looking for an alternative with either an offset or 45" inches cut. From posts the KK II 48" seems popular but worried its a bit heavy 600lbs and is rated for PTO of 20 to 30 and I'm thinking its to much for the little BX tractor:(. The KK XB will not fit the 3 point Quick hitch.:(
So does anyone have experience with with CCM CR-45 or 50 on a SCUT?
Ore even the CCM MR-110 or MR-130 series? or should I just get the Woods?
   / Tiller Advice for SCUT #2
I use a Landpride 48" on my 16hp B7100. It will definitely load it down once the ground is fluffed enough the tiller can bury itself.... but you don't need to till past that point anyway. You should be fine with a 48" tiller.
   / Tiller Advice for SCUT #3
I use a WOODS GTC52-2 on my TZ25 in the clay here in upstate NY. It performs FLAWLESSLY! It also works with the Speeco quick hitch I have. My opinion is worth 2 cents.....but I highly recommend it.
   / Tiller Advice for SCUT #4
gdBX,
I thought the KK II TG 48 at 600 lbs might be too heavy for a smaller tractor but a number of guys have them and say no problem. I have a BX2350 and the word is that the 3 point can handle it easily.
King Kutter also makes the KK TC 48 (note: the KK TC 48 is not the same as the KK TG 48).
The KK TC 48 weighs 425 lbs but is made in China as opposed to USA as per conversation with King Kutter Co.
Hopefully some guys with some practical experience will chime in. The KK II 48 is, according to a lot of folks on this site, about the best deal going.
   / Tiller Advice for SCUT #5
Go to EverythingAttachments.com and look at hard their T5 series. Ted, Rick and Gerry are very customer service and satisfaction oriented and you can't beat the free shipping.
For my John Deere 2520 with 20 PTO HP the JD dealer recommended a LandPride 58" reverse till tiller. But after looking at LandPride, Woods and others I settled on a 56" T5 and expect to till 7 inches deep.
Primary considerations were:
* Wet or dry soil
* Clay, sandy or rocky soil
* Cutting Width
* Weight
The only problem is that tillers are hard to get due to light inventories that are - surprisingly - quickly selling out.
   / Tiller Advice for SCUT #6
Look at the Kubota website for your tractor, It shows lift capacity is 992 Lbs at lift point and 661 Lbs 24" behind the lift point. http://kubota.com/f/products/BX24specs.pdf
Your tractor will handle the CR45 or CR50 tillers. They have a hitch designed for your limited CAT 1 3 point hitch.
   / Tiller Advice for SCUT #7
gdBX,
I have a KK 48'' on my BX1500 . They work fine together.
Do you happen to know which model of KK your using is the TC, TG or XB.
I'm curious that several like land pride and woods appear to use 4 tines and others use 6. Wondering which requires more hp to turn, seems the 6 might be easier for a smoother bite but is it offset by having to rotate more weight?
   / Tiller Advice for SCUT #9
Do you happen to know which model of KK your using is it TC, TG or XB.
* is it offset by having to rotate more weight?
It's a TC and it has 6 tines.
*The 6 tines are Not a problem for this tractor.
This is a little BX with only 15 horse power and it handles the tiller just fines so your BX24 should hardly know it's back there.
I could use the tiller on my BX23 also but I just leave it on the BX1500.
Saves having to remove and install both the Back Hoe and the Tiller to use them.;);)
All in all a real :cool: set up.
   / Tiller Advice for SCUT #10
I have a BX22 and just used my new KKII 48" the other day. It was SLOW going on earth that hadn't been tilled before. The soil was just moist enough to not produce any dust. The tiller did a good job, but it did give the tractor a workout. I did two passes, and I was able to move slightly faster on the second pass provided I didn't try to dig up more and just retill the spoils from the first pass.
I can't remember if it is a TC or TG (it's raining right now, so I'm not going to go look), but it is definately not the XB. It is the heavy one, so must be the TG.
I tilled 100 ft of some really dry dirt too, and it chewed right through it w/o thinking about it. Although I think half of it blew away because it was so dry.
So it's going to depend on your soil conditions... If you're going to do moist/wet clay, forget it.
Jeff
2004 AGCO Gleaner 3000 Corn Header (A55315)
2004 AGCO Gleaner...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
Kubota L4701 (A53317)
2017 JOHN DEERE 323E SKID STEER (A52709)
2017 JOHN DEERE...
2005 Freightliner Sportcoach Elite MH401TS 40ft. Class A Motorhome (A55853)
2005 Freightliner...
2018 Ford F350 (A55973)
2018 Ford F350...
