Tiller advice for new Kubota B2650 owner
   / Tiller advice for new Kubota B2650 owner #1
markjtrickey
Maiden, NC
Kubota B2650
Hi,
Looking for advice on a 3PH Tiller to put behind a Kubota B2650 (26HP/19.5HP PTO). The dealer where I'm buying the tractor only sells Woods, which I understand to be a good brand, but the one he has in stock is their lower end model, only 4 tines and pretty darn expensive. I have looked at the King Kutter models, but the models I looked at seem to be missing the adjustable offset which I think may come in handy if I want to leave hard pack rows in-between tilled rows.
What I'm hoping to get is one wide enough to cover tracks if I run it centered (maybe 52 - 54 inches), 6 tines, forward rotation, and adjustable offset. And I want it to last forever and be cheap :laughing: Actually, money is not the primary factor. It's not going to get daily use or anything, but I want it to last and not leave any parts behind in the garden :)
I have looked at the Sicma T5-60 60 over at McGee's and it seems to fit my needs, but I have heard the heavier the better and the Sicma's seem on the light side compared to others. There was a Tarter I looked at that could be used both forward and reverse rotation, but the HP rating was above the 19.5 I have available at the PTO. Are the HP ratings given by the manufacturer's hard and fast rules on the low side? It seems once I get into models where the weight gets up to 500 - 600+ lbs the minimum HP rating jumps up to 25+
Thanks,
-mark
   / Tiller advice for new Kubota B2650 owner #2
If you are planning on using a hiller/bedder after tilling the width (covering your tracks) is not really an issue...a couple of cheap 'S' tines on the hiller/bedder tool bar will take care of the packed down tracks etc...
   / Tiller advice for new Kubota B2650 owner #3
Jeff, The Land Prides only seem to have 4 tines per flange. If I was to be honest, I don't know how much difference that will make, but it seems logical that 6 would be better than 4.
/pine, I have much to learn. I'm not sure what a hiller/bedder does, but it sounds like something else I need to get :)
   / Tiller advice for new Kubota B2650 owner #5
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
