Tiller -- acres per hour??
/ Tiller -- acres per hour?? #1
schole
Ontario, Canada
Kubota L3400
How many acres per hour can one comfortably till with a 34 hp tractor and 5' or 6' tiller? Assume sod, loam or sandy soil without rocks, only one pass (I realize more than one pass would be necessary).
I have an L3400. I would like to turn over my garden and prepare for new ones -- I can see the tiller being great for this. Could I use it to till a 3 acre pasture? Or is this just too much....get some discs and a plow instead??
I realize this is related to the tiller/disc thread...I didn't want to change direction on it.
Thanks so much!!
Shawn
/ Tiller -- acres per hour?? #2
Several answers to several questions here.
1.) I use a 72" tiller behind a 60 HP tractor. With it's low gear groundspeed being ideal for a tiller, I can do about 1-1/4 acres an hour, tilling sod to a depth of about 6".
2.) Some conditions will allow you to complete the tilling in one pass. (Ideal soil moisture, no heavy sod, good soil)
3.) You can do as much area as you want. I've tilled as much as 20 acres before. (Pasture re-seed job)
4.) You are at the fine line with regards to HP/tiller size. Your ability to use a 72" tiller with that HP depends on what sort of low-gear speed you have. The slower the better.
5.) I still (moldboard) plow some pastures when renovating. I also chisel plow a few. Some get a disc taken to them, and others get a tiller. It depends on a long list of things. (Not least of which is what the customer wants)
/ Tiller -- acres per hour?? #3
Suggest you plan on investing a day in a project like you describe. It's not something you can predict is going to take 3.75 hours, give or take 10 minutes.
As a frame of reference, though, I tilled a 2 acre pasture with my 72" tiller for re-planting. Seem to recall it being about a 1/2 day job since it required 3 passes, going from hard-packed, weed-filled ground to a finely pulverized, seed-ready field.
How fast you can go will depend a lot on soil type and moisture. Sandy soil goes quicker; soggy or lumpy clay takes longer.
/ Tiller -- acres per hour?? #4
I tilled close to 3 acres in about 5 hours on Saturday with a 60" tiller. VERY heavy clay, hard as rock, with vegetation. Only 3" deep or so, one pass.
Given the conditions, I was happy with the speed of it. I have a disk and I have done a similar area. It took 3 passes and I still did not end up with the reults I got with the tiller.
I am planning to sell the disk, I can't imagine using it again since I have the tiller.
/ Tiller -- acres per hour?? #5
Maybe figure you might go half as fast as you can walk, which would be about 1.5 miles an hour. Pick 1 mph and calculate that acreage, then do it for 2 mph. Figure you are then in the approximate range of your limits.
5' tiller would give you about 0.6 acres in an hour, and a 6' tiller would be 0.7 acres. That is assuming you will get a full width pass and not have any overlap. Double that for 2 mph and you can get an approximate idea.
If you find you can go faster, which maybe you can, then estimate how fast and recalculate.
/ Tiller -- acres per hour?? #6
</font><font color="blue" class="small">( Maybe figure you might go half as fast as you can walk, which would be about 1.5 miles an hour. Pick 1 mph and calculate that acreage, then do it for 2 mph. )</font>
Somewhere, in one my classes in college, it was stated that the average human walks at about 5 MPH.
I just got a 52" tiller today and only did a couple of small areas of established grassy soil. I think I could go full depth (almost 7") if I were to crawl along, but I tried different speeds and found that I would have to make at least two passes to get good depth at higher speed. After the first pass through the grass, I was able to go full HST pedal, low range/ on my CK20HST and it dug quite well. It's that first pass through thick sod that slows one down. I couldn't guess how long it would have taken to do an acre. I'll know that after a while though!
John
/ Tiller -- acres per hour?? #7
KiotiJohn
I've always heard average walk was 3 mph (I know I am just a bit under that unless I push to walk fast), so was thinking half that fast was 1.5, and then calculating at either side of that (1 mph and 2 mph). But I don't have a problem with what others think is the average walking pace.
I did find a site: http://healthfullife.umdnj.edu/archives/METsTbl.htm )
that indicates 3 mph is a brisk pace, and that average is 2-2.5 mph. There are probably others that say different too.
Will be interested in your experience, which will be better than some math calculations. /forums/images/graemlins/grin.gif
/ Tiller -- acres per hour?? #8
</font><font color="blue" class="small">( But I don't have a problem with what others think is the average walking pace. )</font>
Here lately, I'd do well to make a mile in two hours!
If the water around here would clear up, I could go find out how long it takes to do an acre! Rained hard here last night adding to an already well soaked turf. Too wet to till.
It's also too wet to go hog two pastures down the street, and they're getting quite tall. I'm sure the owner is anxious to get them down to size so the place doesn't look so over grown.
good seat time to you guys, if you can get it.
John
/ Tiller -- acres per hour?? #9
</font><font color="blue" class="small">( the average human walks at about 5 MPH )</font>
</font><font color="blue" class="small">( always heard average walk was 3 mph )</font>
I agree with both of you. I always heard that "normal" walk speed was a range of 3 to 5 mph. /forums/images/graemlins/laugh.gif I've always walked fast and attribute that to trying to keep up with a long legged, long striding father when I was a kid. /forums/images/graemlins/tongue.gif And my wife won't hardly walk anywhere with me; tells everyone there's no way she can keep up. /forums/images/graemlins/crazy.gif
/ Tiller -- acres per hour?? #10
3 acres of pasture renovation. I'm guessing 2 passes in an afternoon. The first pass will be slow, breaking new ground and I'm sure you will find a few stones. The second pass will be twice as fast and you'll get more depth. Definetely not too big of a job for your tractor and a 5 or 6 ft tiller as long as you have a hydro transnission. If not, get the smaller tiller. I've got a 40 horse and a 6' tiller, without HST I'd be hosed.
Wow! Thanks so much...excellent replies. I get the sense that if I had a chance to buy a tiller, it would replace plow, discs, and harrows, give a better job, and do so at a reasonable pace for my pasture maintenance. Not to mention great for gardens, final landscaping etc. I did not realize they could be used so well for acerage. Thanks again.
/ Tiller -- acres per hour?? #12
I guess one thing I should say about disk vs tiller is that if you have a field that is already just dirt, that is, not hard and packed with vegation, a disk will go through it fast and do a pretty good job of loosening it up. In this situation the disk can be faster if the soil is decent. Otherwise the tiller is superior.
/ Tiller -- acres per hour?? #13
schole, are you sure you need to be using dangerous equipment like this? </font><font color="blue" class="small">( 4 kids...don't know where they're comin' from... )</font> /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
John
/ Tiller -- acres per hour?? #14
If you ever get on a treadmill and set the speed to 5mph, you'll have to jog to keep up - 3mph is a good pace and anything over 4mph requires jogging unless you're an accomplished speed walker...
/ Tiller -- acres per hour?? #15
</font><font color="blue" class="small">( If you ever get on a treadmill and set the speed to 5mph, you'll have to jog to keep up - 3mph is a good pace and anything over 4mph requires jogging unless you're an accomplished speed walker... )</font>
No need for a treadmill.... My Gator won't fit on it, and I seriously doubt my bum knee would be able to jog a mile anymore... /forums/images/graemlins/crazy.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/grin.gif
KiotiJohn, good thing the wife likes tractors, eh?
/ Tiller -- acres per hour?? #17
I've been working on the same thing. 72" tiller, JD 4400, I run in 1st gear, A range, about 1.5 mph. My only problem is rocks, lots of rocks. My poor tiller has been taking a real beating. I have to stop and un-jam the tiller from time to time and I'm sure the people who live near by don't really like the noise.... Good luck.
Troy
/ Tiller -- acres per hour?? #18
Great question! I'm glad you asked. I'm really interested in a tiller now. Recently harrowed 2 acres and had to make 3 passes. In the areas that had bermuda, the discs never really broke through. I was thinking about using poison, but it sounds as though a tiller is what I need. Maybe both? Also, I've heard that a tiller is a lot easier on your tractor.
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
2021 CHEVROLET LCF 4500 16FT BOX TRUCK (A59905)
2021 CHEVROLET LCF...
10ft. Fork Extensions (A59228)
10ft. Fork...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
Jaw Crusher (A59228)
